Spongy Brakes - need some advice
Old Aug 21, 2013 | 11:32 AM
vwalkerg37's Avatar
vwalkerg37
Originally Posted by unknowndesi
At any point did your mc/brake fluid reaevoir go dry? If it did you need to bench bleed the mc or use one of those vacuum brake bleeding tools to get all the air out of the system. Good luck!
you know it might have....I was on the inside of the car doing the pedal work....
I am having some springs and other items installed at a shop that specializes in brakes as well. I will let him know that it might have run dry and see if they can fix it.
How do you bench bleed the MC?
Old Aug 21, 2013 | 11:35 AM
vwalkerg37's Avatar
vwalkerg37
Originally Posted by daonlyillwiz
You have to bleed your brakes, end of story.
I have bled them twice myself and once at the Riverside Infiniti (which costs me 140.00)
Did not change the pedal at all. I have put almost two 750 ml bottles of ATE super blue into the system.
I do agree with you and think there is air somewhere..the trick is how to get it out.
Thanks for the input.
delfinparis
Oct 8, 2015 06:06 PM
Mattimus
Oct 4, 2015 01:33 PM
ajosowiecky
Sep 30, 2015 12:15 PM
BurtoN86
Sep 30, 2015 03:32 AM
