BC Coils
Old Jun 30, 2013 | 12:54 PM
pauliewalnutzz's Avatar
pauliewalnutzz
BC Coils
Quick question. Can you lower the rear without taking the bolt out of the strut?? Some people say just turn the strut collar. Others say you gotta take the bolt out. Any info would be good
Old Jun 30, 2013 | 01:12 PM
nukee26's Avatar
nukee26
They way you supposed to do it is remove the bolt, adjust the ride height through spring adjustments, then reset the pre-load by adjusting and rebolting the strut.
Old Jun 30, 2013 | 04:04 PM
whs^^ raise or lower the spring collar nut the amount you want, preload the springs, then raise or lower the shock height the same amount that you adjusted the collar ring nut.
Murkr
Sep 28, 2015 10:45 AM
m3clubracer
13
Sep 28, 2015 09:54 AM
killingforpeace
Sep 27, 2015 05:50 PM
VQCrew
Sep 26, 2015 01:19 PM
Wreckreation
Sep 21, 2015 06:27 PM
