Help HELP!! Stance Coilovers installed...questions
Old Mar 14, 2013 | 10:09 PM
shawnberry45's Avatar
shawnberry45
on 2008 G37S Coupe, ride is great...obviously need an alignment but Im told I should wait a week?
I have the SPC front camber kit in and the rear in as well...the front wheels look great BUT the rear wheels are tilted inward...
ok to drive like this? or should I get the rear camber and alignment adjusted right away!!??
please let me know was going to do a long drive tomorrow so kinda worried!
Thanks! GREAT Setup by the way! very very quiet and smooth ride so far!
Old Mar 14, 2013 | 10:42 PM
Coilovers typically settle quicker than lowering springs, so you might just go ahead and at least get the rears aligned closer. Maybe you can tell the alignment shop your situation and just want to get the back closer to spec so you can at least drive it safely since you've got a big drive ahead, and come back in a few days for a "real" alignment, can't hurt to try. A bit extra camber is no big deal short term but if you have one wheel way out or your toe is off by much than it's best to get it set up at least as best you can before your drive. My coilovers settled completely in 3 days, my springs took 6 days FWIW.
Stevolkz33
May 28, 2016 02:36 AM
BurtoN86
Nov 3, 2015 04:40 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
Edward Cheng
Sep 8, 2015 11:56 AM
