Front Sway Bar not centered
Old 01-30-2013, 10:54 AM
michg37
michg37's Avatar
Question on the instructions, they indicate:
"On the placement of the REAR endlinks, Hotchkis recommends installing the endlink into the hole NEAREST the end of the bar. This is the lightest setting. The stiffness can be adjusted at a later point to fine tune the car for your driving preference"
But what about the front? are the holes nearest the end of the bar the lightest setting as well? it doesn't say anything in the instructions.
Thanks!
Originally Posted by michg37
Question the instructions indicates:
Thanks!
Yes, the same applies in front. Outermost hole is softest, innermost hole is stiffest.
Old 01-30-2013, 10:56 AM
michg37
michg37's Avatar
Thanks, UPS tracking number says they'll be here today at some point. Figured i would go over the instructions in the mean time. i already have the car up on stands and old one loose and ready to come off
Old 01-30-2013, 04:37 PM
GTLAW
GTLAW's Avatar
Eibach Sways FTW! I don't trust any other.
Old 02-06-2013, 04:59 PM
TVPostSound
TVPostSound's Avatar
I should also mention that it is the OEM sway bar and links, been considering upgrading to Hotchkis sway bars if it'll fix the issue
OEM sway bar bushings DO NOT get greased.
It uses the binding friction of the bushing to aid in stiffness.
Only aftermarket bars with Urethane bushings get greased.
Maybe thats why its slipping, or your front end could be tweaked.
Old 02-06-2013, 10:52 PM
Track Bandit
Track Bandit's Avatar
I'm with TVPostSound. Make sure the front end hasn't been tweaked in some way. It's very unusual for a sway to always shift to one side only given your making left and right turns all the time in a street car. If it hasn't been done, have a good alignment shop who can do a frame check look at the car since it's an insurance repo. If the frame has been tweaked, then you want to know that early to have it repaired and notify the company who sold you the car that they didn't fully disclose all the damage to the car and have them pay the repair. Hopefully nothing is found. Good luck and you'll love the Hotchkiss sways.
Al
Old 02-07-2013, 01:04 PM
TVPostSound
Thats what she said!!
Old 02-07-2013, 01:05 PM
TVPostSound
SInce when did Hotchkis get adjustable front bars?
Old 02-07-2013, 02:30 PM
I believe they have always been adjustable from the time they came out for the X models, no?
Old 02-07-2013, 09:47 PM
awais
awais's Avatar
That's correct, Hotchkis AWD front bar has two settings.
Old 02-08-2013, 07:18 PM
michg37
michg37's Avatar
No issues anymore since i put on the new front bar, the ring on the drivers side was broken and sliding around allowing the bar to shift. It was always probably shifted to the passenger side because whenever i got home to check it i would have to make a left to get into my driveway on a diagonal incline.
Chances
04-28-2020 07:52 PM
Mattlorentzoe
08-21-2015 03:54 PM
bkouba88
16
08-21-2015 12:44 AM
Jensen Mathew
08-16-2015 08:06 PM
Quick Reply: Front Sway Bar not centered
