Spring and shock combo
As we all know tax season is here.. Once I get my refund I want to lower my car, but I'm trying to avoid getting the camber kit.
Since I have an X coupe I'm thinking Swift springs, with bilstien HD shocks tuned for a G37S.
Thoughts?
Thoughts?
So after doing some research, I think G37S springs on my X would be a better match for me. Only problem is the rear sags a bit.. But an isolator should raise it up.
Anyone currently running this set up?
I would imagine I wouldn't need a camber kit cause I would be at the same height as a sport.
If you haven't already seen this
https://www.myg37.com/forums/brakes-...e-x-coupe.html
I have the X also, an I was going to do the same but I decided to just go with Eibach pk.
Soon going to get some BC Racing coilovers.
How did you like the eibachs? What kind if drop did you get and how was your alignment?
I got them last July and still haven't gotten an alignment.
the guy who installed the eibachs told me I didn't need an alignment.
I won't be driving it much since it will be in my garage at home while I'm in school so I won't really have to worry about significant uneven tire wear.
They were good at first but I feel like the ride got harsher later on
I just did a quick detail and edited the picture with SnapSeed, iphone app
Sorry I don't have any pictures up close to the wheel gaps and the bottom of the car to see how low it is. Still in school and car is at home
If I can remember, I think it went from 3-4 fingers to 1 finger that was able to fit in the wheel gap, we have different size fingers so I'm not sure if that'll help
I scrape the bottom when I get off the driveway, I need to snail my way through to not scrape
