Eibach Pro Kit on G37xS Sedan
Old Jan 31, 2013 | 09:24 AM
  #46
dragion's Avatar
dragion
Whenever you lower a G the wheels will tuck into the fenders and look sunken in when dropped, wheels spacers between the rotors and your wheels will bring the wheels out closer to the fenders. Spacers typically run about $120 or more for a pair. You will also need an alignment, usually about $100-120.
Plus the possibility of camber need adjusting, so a camber kit might be needed too.
Old Jan 31, 2013 | 09:34 AM
  #47
dragion's Avatar
dragion
Originally Posted by tbulsara
i went with the 2008 g35x eibach pro kit. love the drop. sits even. PM me if you have any questions!
Thanks!
Originally Posted by rm2342
How are they price and service wise? I have spoken with them via email about my 350z, but never had service there.
Originally Posted by Boywdr
They are about the only respectable place that warrants there work in that area they usually let me talk them a few extra bucks cause I always go there my springs were only 180 on very short notice on a busy day.
It really depends on what you need done.
If it is "Lighting" related, ask for Brian...I've had both positive & negative results from them though all the years I have required their service.
You should consider Royal Wheel & Tire located in Arlington, MA...only good results from John there.
Old Jan 31, 2013 | 10:19 AM
  #48
daonlyillwiz's Avatar
daonlyillwiz
If i was to get springs i would personally go with prokits simply because the drop is moderate and ride quality isnt completely destroyed like some other springs do.
HOWEVER, keep in mind with springs you have a more likely chance of blowing your shock absorbers etc... might as well go with coil overs because it will save you money in the long run and also comes with stiffer spring rates for a more sporty ride..
Old Mar 21, 2015 | 03:46 PM
  #49
ILUCKYI's Avatar
ILUCKYI
Originally Posted by Built2Prfctn
Looks nice. What size tires are you running and is there rubbing or the need for a camber kit? AWD or rear wheel drive? Thanks!
rbgrant
Buying & Leasing
Nov 12, 2020 11:53 AM
35Sport
Feb 2, 2017 11:32 AM
G37xhibeet
Nov 15, 2016 09:29 AM
BANNISTER
Dec 10, 2015 04:14 PM
