Help Lighter Steering with Hotchkis Sways
Old Jul 6, 2012 | 11:04 AM
Damn Dirty Ape's Avatar
Damn Dirty Ape
Originally Posted by harp00n
Hotchkis AWD sways have two holes in the front (stiff/soft)
Which hole is which? F/R on that front AWD bar?
Old Jul 6, 2012 | 11:26 AM
Rad_Slinger's Avatar
Rad_Slinger
The one closest to the end of the bar is usually the softer
Old Jul 6, 2012 | 11:40 AM
Damn Dirty Ape
Just greased mine yesterday and can't tell you which it is on, ugh!
Old Jul 7, 2012 | 03:27 AM
rokuss's Avatar
rokuss
Originally Posted by supadice
Has anyone with Hotchkis sways noticed lighter steering after installing them? Im on the stiffest in the front and middle in the back. If you have experienced lighter steering what is the remedy?
I have the same lighter steering after I installed the Hotchkis sway also but I don't have an X. The front is on the only setting and the rear is on the softest setting. When driving at highway speeds and turning the steering wheel from left to right, the car feels like the front steering is sloppy. I've never found a solution.
Old Jul 12, 2012 | 09:18 PM
2009G37Bandit's Avatar
2009G37Bandit
WOW, that sucks. I just got mine today. On my 2001 vette (Z)^ sways) made it feel stiffer.
Old Jul 20, 2012 | 12:27 AM
Track Bandit's Avatar
Track Bandit
Hotchkiss sways and GT Spec strut brace
Well I also have the Hotchkiss sways and I found that with the setting in the middle on the rear sway the front end still gave up earlier than the rears. So just like SUPADICE I opted for the firmer setting on the rear and it seem more balanced on my G37S. Things felt pretty good, steering response was very quick, even flatter with the Eibach springs, and I think the steering feels kind of heavy given we have power steering on this car. The power steering is very course in it's operation compared to others I've driven especially the newer electro/pneumatic types.
I then installed a GT Spec strut brace and honestly I didn't think it would do much, but I was wrong. The front end sticks much better but it also seems to transmit more side to side jolts while driving down the road normally. I've tried it again with it off and it was smoother just going down the road and the front end wasn't quite as planted in the corners. Put it back on and the front end had more grip but I also had more road jostling on middle to large irregularities while driving normally. With it on it seemed I could point the car during hard cornering better and then steer with the throttle as well more easily. The jury is still out on the GT Spec brace for me. No more suspension mods until the shocks finally give out.
Al
fuzzed
Aug 21, 2020 09:35 AM
djdiskino
Sep 29, 2015 07:18 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
GFTW
Sep 19, 2015 03:52 PM
