Brake light coming on when flooring it?
Old Apr 20, 2012 | 07:57 PM
jesse550's Avatar
jesse550
Never really floored it in first gear before but did twice today and the foot-brake light momentarily flashed both times. Anyone experience this before?
Old Apr 20, 2012 | 08:02 PM
awightguy's Avatar
awightguy
Mine does that sometimes too...I was actually about to post something about it.
I have an 08 G37S, when i punch from a dead start my hand brake light comes on and then almost always is followed by the "slip"/"VDC OFF" lights (which idk if its just mine....but is there anyway to turn VDC back on once you lose traction w/o restarting the car???)
Hope someone can answer this stuff for man GL!!
Old Apr 20, 2012 | 08:04 PM
buckets's Avatar
buckets
Your brake fluid is low.
Old Apr 20, 2012 | 08:07 PM
awightguy's Avatar
awightguy
+1 ^^^^ pwned
well now I feel like a retard....lol Is that the only explanation for it to do that? Just curious, because i noticed mine was low a while back and refilled it....but I guess it could be that time again.
Old Apr 20, 2012 | 08:12 PM
buckets's Avatar
buckets
Check your pads too
Old Apr 20, 2012 | 08:15 PM
jesse550's Avatar
jesse550
I'll have to get most of it checked out soon, got the car at 45k miles now going on 50k, and I sure as hell wouldn't be surprised if the previous owners didn't change the brake fluid or even the pads.
Thanks for the responses guys!
Old Apr 20, 2012 | 09:01 PM
speedracer g37's Avatar
speedracer g37
you sure it's the brake light and not your slip light?
Old Apr 20, 2012 | 09:02 PM
jesse550's Avatar
jesse550
Yes I'm positive, it was the red light in the bottom left that said brake.
Old Apr 20, 2012 | 09:24 PM
speedracer g37
then it's what buckets said.
Old Apr 20, 2012 | 09:29 PM
kmchenry's Avatar
kmchenry
Both of mine came on, refilled the brake fluid no more problems with the lights.
Old Apr 21, 2012 | 01:11 AM
CaptainObvious's Avatar
CaptainObvious
https://www.myg37.com/forums/g37-cou...eleration.html
https://www.myg37.com/forums/g37-sed...lp-please.html
https://www.myg37.com/forums/g37-cou...-comes-on.html
https://www.myg37.com/forums/g37-cou...uring-wot.html
Old Apr 21, 2012 | 01:36 AM
TwoThree's Avatar
TwoThree
Yep, multiple threads on this. Simply add some brake fluid. Sometimes its pad wear, but more than likely a little brake fluid added does the trick. It did for me.
Old Apr 21, 2012 | 12:27 PM
JOHNNYG37S2008's Avatar
JOHNNYG37S2008
yep same problem my rear brakes were bad which caused more brake fluid to be used which makes the light come on.
Old Apr 21, 2012 | 02:20 PM
Tazicon's Avatar
Tazicon
Also note this is something that is typical in cars in general. It's not just a G thing.
Old Apr 21, 2012 | 05:24 PM
Fresh Mobile's Avatar
Fresh Mobile
I have the same issue with brake light on hard acceleration...1st gear 7k rpm its flashes when i switch to 2nd with WOT! R2C comes alive here I probably get 12mpg
Anyways...make sense...since my last oil change service consultant told me my rear pads are low about 5mm and said i should change it on next oil change.
