Chamber kit
Old Mar 13, 2012 | 09:00 PM
flipside07's Avatar
flipside07
Chamber kit
Hey guys I need to get a rear chamber kit any ideas on what kind I should get, also my front is off a little should get the front as well?
Old Mar 13, 2012 | 09:14 PM
I'm pretty sure you mean a "camber" kit. SPC and Eibach are the same parts. The Eibach branded ones tend t be a little bit less expensive. If you want to adjust the front back to spec then get the front arms as well as the rear.
Old Mar 13, 2012 | 09:23 PM
I assume you recently lowered your car, you can run a little extra camber in the rear but if the toe can't be brought into spec then you'll have bad tire wear. If you're not lowered too much like on Eibach springs you might just need the toe bolt kit. Anything lower and you should get the Eibach/SPC arms that BlackBetty mentioned.
Old Mar 14, 2012 | 03:32 AM
Presto's Avatar
Presto
do you have 4WAS in your car?
beng37s
Dec 8, 2019 01:21 PM
optikol
Jan 28, 2016 07:31 PM
RexHavoc
Oct 2, 2015 11:47 AM
hamkha1ebay
Sep 28, 2015 02:38 PM
