Help Installing springs vs installing coilovers
Old Feb 23, 2012 | 10:24 PM
willstophe's Avatar
willstophe
Hi everyone. I just wanted to raise a question in regards to installation and that is the question of which is harder to install? Coilovers or lowering springs? I am not experienced at this and I'm trying to learn (obviously). Input would be appreciated.
Cheers.
Old Feb 23, 2012 | 11:06 PM
Coilovers are a little easier than springs. If the coilovers have the upper spring seat attached instead of reusing the OEM one (most do), you don't have to disassemble or reassemble the front units or compress the springs. You just remove the fronts as a complete unit and install the new coilovers as a complete unit. It's a bit easier that way as one of the most tedious (and dangerous) parts of the job is spring compression.
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
sLADe781
32
Nov 28, 2015 03:23 AM
cparise
Aug 19, 2015 01:51 PM
MeatySock
Aug 14, 2015 08:25 AM
stpncaV37
Aug 10, 2015 08:05 PM
