Lowered in snow
Old Feb 7, 2012 | 12:40 PM
tejasg37x's Avatar
tejasg37x
Originally Posted by da mayor
Been lowered no problems on my g37x awd coupe in the snow... replaced the front plastic undertray but that was about it
The G37X Sedan is the one that most people have the problem with when using the springs for the G35X Sedan.
If you talk with the people at Eibach, they don't recommend using the 35X sedan springs on the 37X sedan. I don't know why they haven't come out with new springs...
Old Feb 7, 2012 | 02:25 PM
Originally Posted by tejasg37x
My opinion is no...but I don't know for sure. I think the problem is the front springs make the front still sit too high and cause the rear to "sag" instead of lowering evenly using this setup on the 37X. It seems like maybe the 37X front is lighter than the 35X.
Swift has springs that work perfect for this...they had to make a new design for the springs to work on the 37X.
The 09+ G37RWD ATs are a couple hundred pounds heavier than the G35s (due to the 7AT), that's why Eibach and Tanabe have heavier front spring rates for the 37s compared to the 35s. Should be the same for the Xs unless there was some other weight reduction done since 08
Old Feb 7, 2012 | 02:27 PM
tejasg37x's Avatar
tejasg37x
Yeah, it seems weird that the front springs for the G35X make the G37X front sit too high....
Unless it's the rears on the G37X sedan do not have high enough spring rate...?
So specs show the G37X sedan is 87 lbs heavier...so maybe it's the rears from the G35X sedan that aren't right for the G37X sedan? 87 lbs doesn't seem like much though.
Something is definitely different between the springs for the G35X and G37X sedans that does not work and causes the front to sit too high...
amitd79
Feb 21, 2017 04:43 PM
Laguna
Oct 13, 2015 02:46 PM
phamous
Picture Share G Coupe
Sep 30, 2015 02:15 PM
m3clubracer
Sep 20, 2015 09:20 PM
IrishMike
Sep 16, 2015 07:07 PM
