Swift-R Springs Installed! PICS!
Old Jan 19, 2012 | 05:12 PM
  #46
kkokko's Avatar
kkokko
how balanced is the drop? is front little lower? matching rear ?
Old Jan 19, 2012 | 05:43 PM
  #47
gonzo007's Avatar
gonzo007
Pretty balanced IMO - Gap is bigger in the front, but that's because it was higher to begin with. Specs say the springs drop 1.3 front and .8 rear. Not sure I'd want it any different, but I'm also not the type of guy to slam a car. I'll take function over form, but still wanted some form.
Old Jan 19, 2012 | 09:10 PM
  #48
Lawless98's Avatar
Lawless98
After waiting two weeks had alignment done today. With the swift springs toe was adjusted to spec. Camber was not and can not be adjusted without an after market camber kit. Camber was -1.8. Spec is .3 to -1.3. Not concerned about the negative camber as car handles great and will just rotate tires every 3000 miss. Calling for snow tonight so it's time to garage her and switch to my jeep until all the salt is off the road.
Old Jan 20, 2012 | 12:12 PM
  #49
kkokko's Avatar
kkokko
hm.. how far off factory spec is that for the rears?
Old Jan 20, 2012 | 12:35 PM
  #50
scotty_g's Avatar
scotty_g
Thanks for the post lawless we need more awd chronies to jump on the springs. I am seriously considering them instead of bc racing. Although, I heard another set of coilovers for x is coming out in spring.
-Scott
Old Jan 21, 2012 | 12:32 PM
  #51
rokuss's Avatar
rokuss
Originally Posted by gonzo007
I got my Sport Springs installed this past weekend. Haven't driven on other springs to compare against, but have been very pleased thus far. Car feels more planted and stable. Could be the larger tires now too.
Car looks great! Looks like Post Addison Circle apts.
Old Jan 21, 2012 | 01:05 PM
  #52
bat6wc's Avatar
bat6wc
mine get installed on Wednesday! Im stoked
so a camber kit (rear Im assuming) is def needed?
Old Jan 21, 2012 | 10:32 PM
  #53
apexi350z's Avatar
apexi350z
is that front or rear camber spec that you listed? just wondering if just getting the rear camber kit will be sufficient.. thanks!
Old Jan 23, 2012 | 10:37 AM
  #54
xtremeroller's Avatar
xtremeroller
Car looks great.. Those wheels look huge on your car.
Old Jan 25, 2012 | 03:57 PM
  #55
bat6wc's Avatar
bat6wc
Just an FYI, just got mine installed. I am in love. Springs are amazing. Mild drop and way better ride than oem springs.
Old Jan 25, 2012 | 04:06 PM
  #56
dagon68's Avatar
dagon68
Originally Posted by bat6wc
Just an FYI, just got mine installed. I am in love. Springs are amazing. Mild drop and way better ride than oem springs. Pics coming soon!
Another happy customer. Im still lovin mine too. Looks great!
Old Jan 25, 2012 | 06:07 PM
  #57
scotty_g's Avatar
scotty_g
Tell us about driving behavior this week, bat :0 Let's see how they settle.... Are you going to get camber kit?
Old Jan 27, 2012 | 04:40 PM
  #58
bat6wc's Avatar
bat6wc
so far i am loving the springs. def stiffer than OEM but still comfortable. Car rides much smoother now. Alignment is coming this weekend or early next week. Wasnt planning on doing a camber kit but we'll see what the alignment specs turn out to be.
i am very happy with these springs. My 19s go back on in a couple weeks and Ill have some sun pics.
Old Jan 27, 2012 | 05:12 PM
  #59
dagon68's Avatar
dagon68
+1
I am still luvin mine as well. Still need an alignment but now im putting it off until I have funds for the camber kits.
Old Jan 28, 2012 | 11:52 AM
  #60
TVPostSound's Avatar
TVPostSound
Originally Posted by dagon68
OK I finally got a response from Swift:
Those are the correct springs. And yes they are linear. The progressive portion of those springs act as a helper spring and they are fully collapsed at static height.
In creating lowering springs the spring would obviously have to be shorter, and then on top of that we have increased the spring rates a significant amount as well. This in turn will make the spring so short that it will play around in the shock, especially going up driveways or speedbumps. To fix this we have this portion of the spring act like a helper spring, just like what you would see on a coilover setup. These springs are a linear spring on the vehicle.
If you have any other questions please let us know, or if you contact us at the number below.
Thank you for purchasing our springs!
That defeats their whole theory:
Swift Springs USA
