Brakes Pads and Rotors for an 08 S sedan
Old Oct 21, 2011 | 03:40 PM
WannabeSport's Avatar
WannabeSport
Alright, I am sick of pulsating brakes that come and go and warped rotors when I drive aggressively.
What kind of rotors and pads can I get that will be smooth and quiet?? I never shopped brakes for my 05 sedan because the OEMs were so good. My 08? No.
Old Oct 21, 2011 | 03:59 PM
WannabeSport
Apparently the pads on my car have plenty of life left. Would it be more beneficial to just do the rotors then and leave the pads?
Old Oct 21, 2011 | 04:32 PM
whiddles's Avatar
whiddles
I went with R1concepts and they are great. 10k no problems yet. I went with there drilled and slotted rotors with ceramic pads
Old Oct 21, 2011 | 10:01 PM
WannabeSport
Are your pads noisey at all?? WHich ones did you go with and did you get the 'premium' rotors?? Did you do your rears as well as the fronts??
Old Oct 22, 2011 | 12:58 PM
GXXXV X's Avatar
GXXXV X
I also want to upgrade soon, my brakes pulsate like im repetitively slamming the brakes lol its gotten bad
Old Oct 22, 2011 | 07:08 PM
G37Sam's Avatar
G37Sam
I've never ridden a car with brakes as terrible as the ones on my G37, performed TSB at dealership, replaced pads and rotors OEM once, and Stoptech another and still, judders like a belly dancer!!
Old Oct 22, 2011 | 09:32 PM
whiddles's Avatar
whiddles
Yeah I did them all the way around. I used the ones the recomended and if you want I can talk to the owner for you. I got all 4 sets for front and rear for about $370 shipped to my door. they make zero nosie and the look is awesome. I havent even had a problem with rust or anything. Stopping power is a great plus over stock. When I first put them one for like the first 2 days I braked hard just to brake them in.
Old Oct 22, 2011 | 11:39 PM
taek's Avatar
taek
wow now i m interested in this mod as well since my stock brakes are horrible. Did you guy get the premium ones? it looks like they cost about $320 for a pair..
Old Oct 22, 2011 | 11:51 PM
jorwick's Avatar
jorwick
I got stoptech drilled and slotted rotors and am very happy with them. Contact john at jebperformance for a great deal.
Old Oct 24, 2011 | 09:55 AM
Austin713's Avatar
Austin713
im getting some Centric powerslot fronts and regular rears with EBC Red stuff pads installed during lunch today. i too couldnt stand the juddering of the brakes and my rears were due for replacement anyways. ill report back after theyre installed.
Old Oct 24, 2011 | 03:48 PM
eksigned's Avatar
eksigned
...for pads i'm assuming right? someone mentioned rotors, and then i saw $370. lol -- that'd be awesome!
should be careful with drilled rotors -- if they're not drilled COMPLETELY through (which in of itself raises structural concerns) the actual rotors, then they're useful and only for show.
Old Oct 24, 2011 | 04:39 PM
whiddles's Avatar
whiddles
Pads and rotors for $370 is correct. The drilled are fine unless you track your car all the time. Otherwise for daily drivining they are not heating up enough to crack. even in Texas when its 110 out mine are still fine with heavy braking and no cracks yet.
Old Nov 20, 2011 | 06:44 PM
popcornten's Avatar
popcornten
If you haven't made a move yet talk to your infiniti dealer about a TSB. I just brought my car in for shaking steering wheel at highway speeds when I brake and he said there's a TSB for brakes. New pads and hardware that is supposed to keep the discs cooler and help avoid warping, also free rotor machining.
50,000+ miles and track time and I just had the rotors machined for the first time.
Old Nov 21, 2011 | 09:35 PM
Silver37's Avatar
Silver37
I've never had any luck with noise on cross drilled or slotted rotors..tried it on my last car and it created way more noise than the stock rotors. Slotted was way worse than cross drilled. Maybe it was just the particular car. You may want to get a test ride with someone who has them first before you buy.
SBG37
Mar 12, 2021 03:16 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
zero260
Aug 12, 2015 10:02 AM
Peter Reynolds
Aug 6, 2015 07:53 PM
