alignment
Old May 13, 2011 | 12:36 AM
joselitopr's Avatar
joselitopr
alignment
ok I just drop my car with ebach spring i went to sears to do an aligment and after the where done they give me the alignment sheet and on the second page it says ( the manufacturer does not specify front camber and caster adjustment. so the only did the toe. should i take it some where else? I have the sheet but when i try to attach it it says to big. can any one can help me how to attach the pdf file
Old May 13, 2011 | 12:40 AM
JJsBusaRox's Avatar
JJsBusaRox
I would definitely take it somewhere else. Preferably to a shop that specializes in lowering and that kind of stuff...
Old May 13, 2011 | 12:47 AM
sniper27's Avatar
sniper27
probably should also wait a couple weeks before doing so to allow the springs to settle.
Old May 13, 2011 | 01:17 AM
Modme's Avatar
Modme
If you dont have a front camber kit, your front camber and caster cannot be changed. There isnt a point to taking it to another shop unless you get an alignment kit.
Old May 13, 2011 | 01:25 AM
joselitopr's Avatar
joselitopr
ok thanks guys. yes i lowered 3 weeks ago.
Old May 13, 2011 | 01:38 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
if it dosent feel like its pulling dont worry about it
Old May 13, 2011 | 02:09 PM
jran76's Avatar
jran76
Yup, camber and caster is not adjustable on the front with the OEM parts. Toe is it....
Old May 13, 2011 | 02:14 PM
terrycs's Avatar
terrycs
The specs themselves are still available in the service manual even though there is no adjustment on the stock upper control arms.
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
rk325
Oct 13, 2015 01:51 PM
m3clubracer
13
Sep 28, 2015 09:54 AM
rgonz
Sep 11, 2015 04:07 PM
jfisher
Sep 9, 2015 04:17 PM
