Help Wilwood BBK up front, OEM brakes rear... opinions?
Old Apr 30, 2011 | 03:41 PM
Peyman's Avatar
Peyman
Was thinking of doing Wilwood 6piston BBK up front 13" drilled & slotted rotors
and keep rear stock but change rotors to drilled and slotted to match
would this look stupid?
Not much being said about Wilwood on the forums, I thought they were a good brand... anyone have these installed? fronts cost about $1500-1700 shipped
Kit includes parts for both front wheels:
  • Drilled & Slotted, 1.250" Thick x 13.06" O.D. Rotors
  • Superlite 6R Calipers
  • Caliper Mounting Brackets
  • BP-10 Smart Compound Brake Pads
  • Brake Hats
  • All Hardware necessary to install the complete braking system on both front wheels
Complete kit weighs approximately 52 lbs.
anyone know what the OEM brakes weight? i have a non sport
Old Apr 30, 2011 | 06:12 PM
Weiboy718's Avatar
Weiboy718
You should consider the AP Racing instead. I have them and love it everyday I drive
Old Apr 30, 2011 | 06:18 PM
Peyman's Avatar
Peyman
thanks for the advice, going price is about $2400 for the front BBK by AP RACING. I don't want to pay an extra $700-800 just to have the 14" rotors.
do you know if there are any other benefits having AP over WILWOOD?
Old Apr 30, 2011 | 08:19 PM
G37Sam's Avatar
G37Sam
I don't think matching the rear non-sports with 6 piston up front would make for a good balance (unless you're only interested in this for looks)
Old Apr 30, 2011 | 11:31 PM
J2S2M's Avatar
J2S2M
I would rather spend less and have a FULL Akebono kit. That's just me though.
Old Apr 30, 2011 | 11:55 PM
advan37's Avatar
advan37
^ i agree .
Old May 1, 2011 | 02:21 AM
san~man's Avatar
san~man
Your brake bias will be screwed
Old May 1, 2011 | 02:32 AM
GraphiteG37S's Avatar
GraphiteG37S
Why not just upgrade the Akebono pads to some Hawk or Project Mu performance pads... Stainless Steel Brake lines and better brake fluid and drilled/slotted rotors?
Why are you looking for a 6 pot front? will you be tracking or just want it too look better? Aren't you on 18" wheels? Will 6 pot front even clear?
Old May 1, 2011 | 05:01 AM
Peyman's Avatar
Peyman
i searched the forum to see whats needed in doing this swap but couldn't find any info.
what would i need to buy to make this work on my car?
also figured the Akebono is 4 piston and the wilwood is 6
but i guess 4 would be good enough...
Old May 1, 2011 | 05:03 AM
Peyman's Avatar
Peyman
figured 6 piston is better then current setup, just want to know i can stop on a dime if need be. i got 19" volks since last time you saw me
Old May 1, 2011 | 05:28 AM
G37Sam's Avatar
G37Sam
The OP mentioned he had a non-sport so I'm guessing even the OEM sports would be an upgrade. In that case I'd look around for a used set on board, with some rotors and pads and you're good to go
Old May 1, 2011 | 05:33 AM
Peyman's Avatar
Peyman
so all thats needed for the sport brakes is calipers, rotors and pads and thats it?
Old May 1, 2011 | 11:58 AM
san~man's Avatar
san~man
Stainless lines are a must too, upgraded fluid would also be a good idea
Old May 1, 2011 | 06:20 PM
soundmike's Avatar
soundmike
Re: Brake bias. If the Wilwood kit was sized and pieced together properly then the number of pistons shouldn't matter. For any other minor differences in bias, you can always run more aggressive rear pads.
Old May 6, 2011 | 02:46 AM
Peyman's Avatar
Peyman
i ended up getting front / rear wilwood BBK. 14" 2 piece rotors with 6 piston calipers up front, 13" 2 piece rotors w/ 4 piston calipers rear. install will take place in a week or two. pics coming soon.
