just got alignment done....feels strange?
Old Mar 11, 2011 | 02:06 AM
MOB's Avatar
MOB
Too much negative camber and too much toe in.
That guy did nothing.
You need at the least rear camber arms, and toe bolts in order to get the alignment close.
well he did something cuz the car doesn't feel right. As far as camber arms & toe bolts....talked with many including reputable vendor/mod shops here on the boards who all said neither of those are necessary with the mild Eibach drop.
Old Mar 11, 2011 | 02:59 PM
soundmike's Avatar
soundmike
Originally Posted by MOB
Toe:
LF .14 - RF .15
That seems way out of spec, i'm looking at the sedan's FSM right now and the range should be 0.00 to 0.08 for the fronts.
Old Mar 11, 2011 | 03:16 PM
MOB's Avatar
MOB
Well then sheit....now what
Old Mar 11, 2011 | 04:01 PM
Weiboy718's Avatar
Weiboy718
Your camber is telling me you should get it, that's a lot of - camber for eibach pk
Old Mar 11, 2011 | 04:11 PM
TVPostSound's Avatar
TVPostSound
Ok so camber numbers are I'm red boxes at the #'s I listed above. Toe numbers are all green. Caster FL is green at 5.1, RF is yellow at 5.4.
Toe should be .04 per side, green should be .00 to .08
Something is wrong.
Old Mar 23, 2011 | 09:24 PM
MOB's Avatar
MOB
Toe:
LF .14 - RF .15
LR .21 - RR .22
based on the other thread I've been reading it seems to me these toe angles are my problem...I kinda like a little neg camber so probably not going to change that.
Are the stock toe bolts likely too short to bring it back in spec because of the drop and do I need different ones?
Old Apr 6, 2011 | 02:32 PM
MOB's Avatar
MOB
need help, track day in 2 weeks!
my current toe settings are below:
LF .14 - RF .15
LR .21 - RR .22
Knowing that this is incorrect, what do I need to purchase/do to correct it and get toe back into factory spec, which I'm told is between .00-.08?
Need some help here pretty quickly so I can purchase and install before my track day....thanks in advance!
Old Apr 6, 2011 | 02:35 PM
P Casey's Avatar
P Casey
get an alignment
Old Apr 6, 2011 | 02:40 PM
P Casey's Avatar
P Casey
its seems like they did something wrong, like they messed with your stock bolt
Old Apr 6, 2011 | 07:38 PM
MOB's Avatar
MOB
that's what I'm wondering, do I need a different toe bolt....do I need an alignment kit.... These measurements are post-alignment at a precision alignment shop and I don't want to go to another shop only to have them tell me I need parts.... uggh
Old Apr 8, 2011 | 08:33 AM
JohnnysG's Avatar
JohnnysG
man... i need an alignment cause my car kinda sways to the left and vibrates... but idk if the vibrating is because i need an alignment? goodluck to you though man because im about to drop on eibachs too but im on a coupe so hopefully im ok
Old Apr 8, 2011 | 08:40 AM
P Casey's Avatar
P Casey
Alignment is only 90 bux, either bring your car to infiniti and have them do it or go to another alignment shop, tell them your car doesnt feel right and your toe is off. You should almost be able to look at your rear wheels and see if your toe is a little off. After they do an alignment, make sure to do a test drive before you leave. Also are you sure they are the springs for the g37 and not the eibach springs for the 350z??? big difference in drop. If that doesnt work see if they can get you a spc rear camber kit and install.
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
rk325
Oct 13, 2015 01:51 PM
m3clubracer
13
Sep 28, 2015 09:54 AM
rgonz
Sep 11, 2015 04:07 PM
jfisher
Sep 9, 2015 04:17 PM
