What degree of camber do you run?
Old Feb 26, 2011 | 12:33 AM
P Casey's Avatar
P Casey
For those with camber kits and a normal set up for 245/35 20x9 and 275/30 20x10.5, Should I run like half a degree of neg camber?? or does everyone like to get back to stock? offsets 32f 42r
Old Feb 26, 2011 | 12:48 AM
Doggy's Avatar
Doggy
Stock is -1.6 I believe, I no a guy who's running -8 rear
Old Feb 26, 2011 | 01:08 AM
P Casey's Avatar
P Casey
I see , so with an h&r drop and running neg half degree camber sit pretty flush with 32 42 offsets with my cv1
Old Feb 26, 2011 | 01:35 AM
VossenG37S's Avatar
VossenG37S
I'm at 1.9
Old Feb 26, 2011 | 01:37 AM
P Casey's Avatar
P Casey
Originally Posted by VossenG37S
I'm at 1.9
what tires and offset are u on right now?
Old Feb 26, 2011 | 01:39 AM
VossenG37S's Avatar
VossenG37S
255/30 w +25 rears!
Steveo47's Avatar
Steveo47
-8... omg. I have -0.75 in the front and -1.8 in the back
Old Feb 26, 2011 | 01:42 AM
P Casey's Avatar
P Casey
i know, when doggy said neg 8 i was like whoa.
Old Feb 26, 2011 | 02:03 AM
Doggy's Avatar
Doggy
I think stock is more neg, I'm not an alignment guy but I'm sure the shop should know. And the guy Ive seen is -5 front -8 rear and he's slammed! It's a white 35 coupe old body, he's on team shyne.
Old Feb 26, 2011 | 02:06 AM
P Casey's Avatar
P Casey
cool thanks, I think ive seen his car, it has work wheels
Old Feb 26, 2011 | 05:35 AM
emyrl's Avatar
emyrl
You should be fine running around -1.5 or so. It's really not that much camber and you should have no worries at all. Our cars come with neg camber stock. I'm currently running -2.5 or -2.6 all around and it's fine. Nothing to worry about.
Old Feb 26, 2011 | 10:04 AM
Loi's Avatar
Loi
I don't believe -.5 camber is possible, even at stock height. Normal camber is around -1.6 and -1.8 plus it's good for cornering.
Old Feb 26, 2011 | 10:12 AM
P Casey's Avatar
P Casey
ok, so basically right around 1.6 to 1.9 should be good. I am heading over this morning to get it done
Old Feb 26, 2011 | 10:15 AM
Loi's Avatar
Loi
Yea but try to get closer to -1.6 though. And remember to elongate the toe bolt hole if you're installing the rear SPC camber kit.
Old Feb 26, 2011 | 10:16 AM
P Casey's Avatar
P Casey
ok, yeah i am
