polyurethane lube for noisey aftermarket sways
Old Jan 8, 2011 | 09:37 PM
RedG37SNC's Avatar
RedG37SNC
With the cold weather I started getting some bushing noise on my hotchkis sways up front. I was curious what other folks with aftermarket sways that replace the rubber bushings with polyurethane are using. I've heard marine lube works well, also hotchkis sells a supergrease, anyone try that yet?
Old Jan 8, 2011 | 09:39 PM
TVPostSound's Avatar
TVPostSound
https://www.myg37.com/forums/d-i-y-i...ars-cheap.html
See above, I do mine every 2 months.
Old Jan 8, 2011 | 09:44 PM
GraphiteG37S's Avatar
GraphiteG37S
I am still using OEM bushings on my Stillen sways but hit them up with a product called magic lube. It's a gel that's used for pool equipment and PVC piping. Mine have been quiet since install.
Old Jan 8, 2011 | 09:49 PM
TVPostSound
Ha!!
Magic Lube is so sticky/good, it takes 20 minutes to wash it off my hands!!!
Old Jan 10, 2011 | 06:16 PM
RedG37SNC's Avatar
RedG37SNC
Thanks, on order are those zerks right angled or do you have to take off that section of the cover to get to them?
Old Jan 10, 2011 | 08:32 PM
TVPostSound
If they were installed right, then the zerks will point out, and you can see them from the side. Turn your steering wheel all the way to one side.
Ahead of where the wheel points you, you will see it.
Also the rears should be pointed back.........if installed right!!!
Old Feb 1, 2011 | 09:41 PM
ipitythefoo's Avatar
ipitythefoo
Ky personal jelly lol
Old Feb 1, 2011 | 10:41 PM
TVPostSound
KY is petroleum based!!hooters
Old Feb 3, 2011 | 01:06 PM
ipitythefoo
Hahahahahahahaha.
Old Feb 3, 2011 | 08:59 PM
RedG37SNC's Avatar
RedG37SNC
Hahahahahahahaha.
It's not water proof though.. washes off to easy.
Old Feb 3, 2011 | 11:53 PM
TVPostSound
Experienced, are we??
Seriously, if you want to do it by hand, it was mentioned earlier the the Simi Valley resident.
Jacks Magic Lube, found in pool stores. It's 100% pure silicone.
Old Feb 5, 2011 | 02:43 PM
RedG37SNC's Avatar
RedG37SNC
Is is just me or is that Superlube so damn thick it's damn near a two man job, one to squeeze the gun and one to hold it up on the fitting.
Old Feb 5, 2011 | 05:13 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
I've still got my OEM bushings and i just greased up the hotchkis sways with the grease that came with them, and I haven't had any problems. Over a year since they've been installed and I haven't relubed them once
Old Feb 5, 2011 | 05:25 PM
RedG37SNC's Avatar
RedG37SNC
Must be the warmer weather, my front end sound like a just married couple on a spring bed whenever I'd go over a speed bump... all's quiet now, they took a lot of grease.
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
parkern
Oct 5, 2015 12:12 PM
djdiskino
Sep 29, 2015 07:18 PM
r0cketm0nkey
Intake and Exhaust
Sep 28, 2015 08:41 AM
