Noise under heavy braking
Old Nov 13, 2010 | 04:18 PM
advan37's Avatar
advan37
hello guys,
Two weeks back i replaced my caliprs/rotors/pads with new Akebono complate kit (Cearmic pads & stopTech drilled/slotted rotos + ss brake lining) . i have g37 journey (non-sport).
From the first drive i slightly feel/hear the noise/shudder when braking at low speeds but the faster i brake down (especially over 50 mph) the noiser it is , even if i touch the brakes at 50+mph this noise/shudder of the car starts (the steering wheel a bit shake).
It's a hard noise to describe but it's very loud and a sort of crunching/scraping noise i think . i went to local shop 4 days back and after checking my car they told me rotors need to be surface ! so i did (only front) , but no change.
The next day i replaced the brake pads with OEM , and also no change , i even did wheel alignment to be sure its not the tires.
I'm pulling my hair out over this , I've wasted enough money on things it isn't.
what else should i do ? shall i surface the rear rotors now?
Plz advice .
thanks
Old Nov 14, 2010 | 12:18 PM
TVPostSound's Avatar
TVPostSound
That means the FRONT rotors need resurfacing.
Old Nov 14, 2010 | 03:25 PM
advan37's Avatar
advan37
Yes that's right ! I resurfaced the all 4 rotors today and guess what... Problem solved !!
But how new rotors and need surface ?
ThankS
Old Nov 14, 2010 | 03:27 PM
w0ady's Avatar
w0ady
weird. i thought you said you had already resurfaced the fronts before.
Old Nov 14, 2010 | 04:06 PM
advan37's Avatar
advan37
Yes I did the front befor , and now all 4 . The first one wasn't good I think, I went to another shop this time .
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
vamarris
Dec 9, 2018 11:10 AM
r0cketm0nkey
17
Nov 23, 2015 03:34 AM
Slapshot1
Sep 27, 2015 08:40 AM
