Sways for your vert.
Old Oct 23, 2010 | 08:39 AM
Topper's Avatar
Topper
Hi All:
Has anyone done a sway bar mod on their vert. What brands are available for the vert.?
Old Oct 23, 2010 | 12:10 PM
Trincap's Avatar
Trincap
I have. Do a search for hotchkiss and you will find plenty of posts.
Oh and it is a fantastic mod.
Old Nov 8, 2010 | 08:03 PM
lier200a's Avatar
lier200a
How bout stillens?
Old Nov 9, 2010 | 09:21 AM
joo030879's Avatar
joo030879
stillen vs hotchkis vs eibach sway bars
Front Bar
OEM - 1.040" OD x 0.150" wall
560 lbs. @ 1" Travel
STILLEN - 1.0625" OD x 0.250" wall
720 lbs. @ 1" Travel
28.6% Stiffer
Rear Bar
OEM - 0.945" OD x 0.130" wall
540 lbs @ 1" Travel
STILLEN - 1.0" OD x 0.188" wall
Hole #1
740 lbs @ 1" Travel
37.0% Stiffer
Hole #2
920 lbs @ 1" Travel
70.4% Stiffer
Specs:
Front Sway Bar 35mm (Ø1-3/8") Hollow
+230% Stiffer than Stock G37
+205% Stiffer than stock G37S
Rear Sway Bar 28.5mm (Ø1.125") Hollow 3 Way Adjustable
+130, 185, 260% Stiffer than Stock G37,
+15, 40, 75% Stiffer than stock G37S
+60, 100, 155% Stiffer than stock G35S
Effective 8-17-2010 the size of this rear bar has been changed from 27mm to 28.5.
Front: 32mm
Rear: 29mm
Footnotes: Front Sway Bar Is Tubular And 2 Way-adjustable/ Rear Sway Bar Is Tubular And 3 Way-adjustable.
<style>.tblGenFixed td {padding:0 3px;overflow:hidden;white-space:normal;letter-spacing:0;word-spacing:0;background-color:#fff;z-index:1;border-top:0px none;border-left:0px none;border-bottom:1px solid #CCC;border-right:1px solid #CCC;} .dn {display:none} .tblGenFixed td.s0 {background-color:#ffffff;font-family:arial,sans,sans-serif;font-size:100.0%;font-weight:normal;font-style:normal;color:#000000;text-decoration:none;text-align:left;vertical-align:bottom;white-space:normal;overflow:hidden;text-indent:0px;padding-left:3px;border-right:1px solid #CCC;border-bottom:1px solid #CCC;border-left:1px solid #CCC;} .tblGenFixed td.s2 {background-color:#ffffff;font-family:arial,sans,sans-serif;font-size:100.0%;font-weight:normal;font-style:normal;color:#000000;text-decoration:none;vertical-align:bottom;white-space:normal;overflow:hidden;text-indent:0px;padding-left:3px;border-right:1px solid #CCC;border-bottom:1px solid #CCC;border-left:1px solid #CCC;} .tblGenFixed td.s1 {background-color:white;font-family:arial,sans,sans-serif;font-size:100.0%;font-weight:normal;font-style:normal;color:#000000;text-decoration:none;text-align:left;vertical-align:bottom;white-space:normal;overflow:hidden;text-indent:0px;padding-left:3px;border-right:1px solid #CCC;border-bottom:1px solid #CCC;} .tblGenFixed td.s3 {background-color:white;font-family:arial,sans,sans-serif;font-size:100.0%;font-weight:normal;font-style:normal;color:#000000;text-decoration:none;text-align:right;vertical-align:bottom;white-space:normal;overflow:hidden;text-indent:0px;padding-left:3px;border-right:1px solid #CCC;border-bottom:1px solid #CCC;} </style><table class="tblGenFixed colHead_0" cellpadding="0"><tbody><tr class="rShim"><td class="rShim" style="width: 0pt;"></td><td class="rShim" style="width: 120px;"></td><td class="rShim" style="width: 120px;"></td><td class="rShim" style="width: 120px;"></td><td class="rShim" style="width: 120px;"></td></tr><tr isfrozenrow="true"><td class="hd"><p style="height: 16px;">.</p></td><td style="background-color: rgb(255, 255, 255); font-family: arial,sans,sans-serif; font-size: 100%; font-weight: normal; font-style: normal; color: rgb(0, 0, 0); text-decoration: none; text-align: left; vertical-align: bottom; white-space: normal; overflow: hidden; text-indent: 0px; padding-left: 3px; border: 1px solid rgb(204, 204, 204);">Spec/Brand</td><td style="background-color: rgb(255, 255, 255); font-family: arial,sans,sans-serif; font-size: 100%; font-weight: normal; font-style: normal; color: rgb(0, 0, 0); text-decoration: none; text-align: left; vertical-align: bottom; white-space: normal; overflow: hidden; text-indent: 0px; padding-left: 3px; border-top: 1px solid rgb(204, 204, 204); border-right: 1px solid rgb(204, 204, 204); border-bottom: 1px solid rgb(204, 204, 204);">Eibach</td><td style="background-color: rgb(255, 255, 255); font-family: arial,sans,sans-serif; font-size: 100%; font-weight: normal; font-style: normal; color: rgb(0, 0, 0); text-decoration: none; text-align: left; vertical-align: bottom; white-space: normal; overflow: hidden; text-indent: 0px; padding-left: 3px; border-top: 1px solid rgb(204, 204, 204); border-right: 1px solid rgb(204, 204, 204); border-bottom: 1px solid rgb(204, 204, 204);">Hotchkis</td><td style="background-color: rgb(255, 255, 255); font-family: arial,sans,sans-serif; font-size: 100%; font-weight: normal; font-style: normal; color: rgb(0, 0, 0); text-decoration: none; text-align: left; vertical-align: bottom; white-space: normal; overflow: hidden; text-indent: 0px; padding-left: 3px; border-top: 1px solid rgb(204, 204, 204); border-right: 1px solid rgb(204, 204, 204); border-bottom: 1px solid rgb(204, 204, 204);">Stillen</td><td class="headerEnd"></td></tr><tr id="sortBar_0"><td class="sortBar"></td><td class="sortBar"></td><td class="sortBar"></td><td class="sortBar"></td><td class="sortBar"></td><td class="headerEnd"></td></tr></tbody></table><table id="tblMain" border="0" cellpadding="0" cellspacing="0"><tbody><tr><td><table class="tblGenFixed" id="tblMain_0" border="0" cellpadding="0" cellspacing="0"><tbody><tr class="rShim"><td class="rShim" style="width: 0pt;"></td><td class="rShim" style="width: 120px;"></td><td class="rShim" style="width: 120px;"></td><td class="rShim" style="width: 120px;"></td><td class="rShim" style="width: 120px;"></td></tr><tr><td class="hd"><p style="height: 16px;">.</p></td><td class="s0">Front</td><td class="s1">32mm</td><td class="s1">35mm</td><td class="s1">26.9mm</td></tr><tr><td class="hd"><p style="height: 16px;">.</p></td><td class="s2"></td><td class="s1">2 way adjustable</td><td class="s1">non-adjustable</td><td class="s1">non-adjustable</td></tr><tr><td class="hd"><p style="height: 16px;">.</p></td><td class="s2"></td><td></td><td></td><td></td></tr><tr><td class="hd"><p style="height: 16px;">.</p></td><td class="s0">Rear</td><td class="s1">29mm</td><td class="s1">28.5mm</td><td class="s1">25.4mm</td></tr><tr><td class="hd"><p style="height: 16px;">.</p></td><td class="s2"></td><td></td><td class="s1">before 8/17/2010</td><td></td></tr><tr><td class="hd"><p style="height: 16px;">.</p></td><td class="s2"></td><td></td><td class="s1">27mm</td><td></td></tr><tr><td class="hd"><p style="height: 16px;">.</p></td><td class="s2"></td><td class="s1">3 way adjustable</td><td class="s1">3 way adjustable</td><td class="s1">3 way adjustable</td></tr><tr><td class="hd"><p style="height: 16px;">.</p></td><td class="s2"></td><td></td><td></td><td></td></tr><tr><td class="hd"><p style="height: 16px;">.</p></td><td class="s0">Retail</td><td class="s3">$436.43</td><td class="s3">$412.95</td><td class="s3">$301.78</td></tr></tbody></table></td></tr></tbody></table>
Eibach 3 thumbs up
1. Stiffer Rear
2. Front 2 Way Adjustable
3. I got mine below Stillen's MSRP.
Hotchkis 2 thumbs up
1. Stiffer Front
2. "Hotchkis Sway Bars", Just sound very sexy.
Stillen 1/2 thumb up
1. The price is cheper than other two brands. However I think to spend $300 on a product little bit better than OEM stock. For me is waste of money.
Old Nov 9, 2010 | 09:25 AM
cvipgo's Avatar
cvipgo
gr8 info thanks
Old Nov 10, 2010 | 12:23 AM
lier200a's Avatar
lier200a
Thanks for info!
Old Nov 10, 2010 | 12:28 AM
wakeboardr116's Avatar
wakeboardr116
Hotchkis are the best you can go with IMO. They specalize in suspension parts. Also they come will all new bushings and hardware and the best part is they have a nipple on all 4 pushings so you can re-grease them easily. Aftermarket sways will start squeeking no matter what brand you get, its just a matter of time. With the hotchkis it's very easy to lube them back up. I got the Hotchkis on mine right after the car and still love them.
Old Nov 10, 2010 | 12:39 AM
joo030879's Avatar
joo030879
I will let you know in case my Eibach starts to squeak. However so far it has been all joy. No matter which brand. Eibach, Stillen, or Hotchkis. Sway Bar is a must. You will experience a hole new level of performance.
Also the Eibach I received came with grease-able bushings, and grease was included. So I am not too worried about squeak.
I did not see Hotchkis's hardware. But our G37 OEM Hardware was pretty will built.
Old Oct 23, 2018 | 01:33 AM
ptnaidu's Avatar
ptnaidu
I am considering Hotchkis too, can you please point me to a particular model number that will fit 2012 G37 convertible? Most websites including Hotchkis has no particular model number, it's confusing to me.
Thanks for any help!
Old Oct 23, 2018 | 09:40 AM
slartibartfast's Avatar
slartibartfast
The convertible is no different than any other RWD G with regards to suspension. Whatever is sold for them AND the 370Z will fit. Hotchkis and Stillen are the two big players in this market but there are others. I moved this thread to a more appropriate forum, please browse here for other brands and reviews of sway bars. Also check the Review forum.
The G really benefits from larger sway bars though a few find the the ride is affected too much for their taste. If you sway more towards the luxury aspect of the car you might not like the difference.
kavcheung
Jan 22, 2016 02:40 PM
djdiskino
Sep 29, 2015 07:18 PM
Mattlorentzoe
Sep 12, 2015 12:08 PM
