Vert vs Coupe Rear Suspension
Old Jun 22, 2010 | 01:07 AM
g37vanbc's Avatar
g37vanbc
So here is the differences between the rear vert shock and coupe shock.
Vert mounts to the front side of control arm and lets say is a pain in the a$$ to get to the top on the shock from the inside has it is very close to the mechanism for the roof
Coupe mounts to the rear side of control arm
Second
The bottom mount of shock on the vert is the same as the front except requires a larger bushing.
Coupe uses a U shaped mount that sits over the mount
This is what i have uncovered so far.
Springs are the same from Coupe to Vert which has already been proven by a couple of members.
Next step is to determine if the Coupe rear camber kit will work on the vert ...........
Old Jun 22, 2010 | 01:18 AM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
g37vanbc, that stamped part looks like the vert camber arms in your third pic and it looks like it has some extra attachment. I've not gotten any response from SPC as to whether they have any compatibility with using the coupes camber arms.
Here's a vid of the coupe camber arms install and it's not looking the same. I'd be wary of anything additional that would need to be removed from the verts camber arm setup.
https://www.myg37.com/forums/brakes-...cs-inside.html
Old Jun 22, 2010 | 01:53 AM
STOOF's Avatar
STOOF
Yeah i said the lower mounts were different months ago. lol
And i really doubt the coupe camber fit is gonna fit the vert. Its completely different.
Old Jul 1, 2010 | 04:01 PM
recycle999's Avatar
recycle999
Would Coupe aftermarket suspension kits fit the Vert?
Old Jul 1, 2010 | 04:07 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
^i think you could make it fit but because of the added weight in the back of the vert you would most likely run into problems
KJA8686
Mar 15, 2021 01:27 AM
JRW370
Buying & Leasing
Apr 8, 2019 09:24 PM
e92ry
Dec 31, 2015 08:02 PM
Redfire32
Aug 11, 2015 09:05 AM
