camber kit, will it fit the vert? pics inside
Old Jun 16, 2010 | 10:53 PM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
So will the spc camber arms fit the vert?
I took some pics of the stock setup. It looks like there is an extra connection to the stock arm which the coupe won't have
Old Jun 16, 2010 | 11:14 PM
cereal2k's Avatar
cereal2k
I just searched about found the install video for the coupe rear camber arms (I could not find it on SPCs site) and it's definitely different.
http://www.youtube.com/watch?v=x0X0SnJQvTE
Old Jun 21, 2010 | 03:46 PM
Loi's Avatar
Loi
Looks a lot different than the coupe's.
Old Jun 22, 2010 | 01:09 AM
cereal2k's Avatar
cereal2k
Yep. It sure does.
Old Jun 22, 2010 | 01:55 AM
STOOF's Avatar
STOOF
So if that rear strut is mounted to that "camber arm" there is absolutely positively NO WAY you can use the coupe camber kit. You wouldnt have anywhere to mount the lower strut.
Old Jun 22, 2010 | 01:56 AM
STOOF's Avatar
STOOF
i bet you can swap the entire control arm and strut though and then use the coupe camber kit hahahah
Old Jun 22, 2010 | 07:05 PM
JohnnyCham's Avatar
JohnnyCham
won't work. the lower arm in the vert also holds the strut. we will have to wait until someone or spc makes the camber arm to hold the strut also.
SBG37
May 5, 2022 10:35 AM
equifire
Aug 31, 2015 03:42 PM
Ipp391
Aug 28, 2015 09:27 AM
kyro840
Aug 9, 2015 01:38 PM
