Took a look at the vert suspension.
Old Apr 16, 2010 | 09:34 PM
STOOF's Avatar
STOOF
There was a G37 vert in the shop today "trying" to get a greddy Ti-C installed, so while it was on the lift i poked my head under there and took a good look at the suspension.
From what i can see, the front looks exactly the same, and the rear springs look exactly the same, but the rear struts ARE different.
The lower mounts on the rear struts are different than the coupe/sedan so coils wont fit.
Although the springs MAY be a different spring rate, they mount up exactly the same, so theres no reason coupe springs wont fit.
You MIGHT just have different drop specs, pretty much the same deal X owners go through, the springs fit but they get a different drop.
So will one of you vert owners man up and put some springs on!!!
Old Apr 16, 2010 | 09:44 PM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
I'll only go so far as to drop the front to even out the gap between front and rear. Without much R&D on the rear drop I'd rather not try and see
Old Apr 16, 2010 | 09:56 PM
STOOF's Avatar
STOOF
Theres no R&D, the springs are the same thing. Just put them in and see how the drop is.
Rear springs are EXTREMELY easy to change, you can do both sides in half an hour in your driveway with a jack and jack stands. Literally.
Theres nothing "special" about the suspension. The only thing thats different is the lower mount on the rear struts are different. Otherwise its exactly the same.
Old Apr 16, 2010 | 11:08 PM
da mayor's Avatar
da mayor
picture your car when you had no people in the car vs the car w/ 2 200lb guys in the rear, thats whats the problem w/ the vert having a coupe lowering spring in the back
Old Apr 16, 2010 | 11:27 PM
STOOF's Avatar
STOOF
ok so its heavier in the rear.
Theres gotta be a spring out there thatll still drop it fine.
Old Apr 16, 2010 | 11:35 PM
Loi's Avatar
Loi
H&R fronts and Eibach rears
Old Apr 16, 2010 | 11:36 PM
da mayor's Avatar
da mayor
you gotta realize how it'll hold the extra 450lbs.
Old Apr 16, 2010 | 11:46 PM
STOOF's Avatar
STOOF
Im not saying itll be the best ride or anything.
I just looked under there and saw that it was all the same, so it should all fit.
I still think someone should try it.
If i had a vert i would.
If the weight is the issue, you could get springs made for something heavier, like an M.
Old Apr 16, 2010 | 11:48 PM
cereal2k's Avatar
cereal2k
Someone had a posed a question on raising the G, not sure if there was a spring solution and if that had tolerance for an extra 450 pounds.
Found the threads
https://www.myg37.com/forums/d-i-y-i...se-my-car.html
Not sure if it would defeat the purpose, but
coupe lowering springs in the rear + spring spacers to raise it to an acceptable level.
Old Apr 17, 2010 | 04:29 PM
Jubbliepuff's Avatar
Jubbliepuff
crap.... i bought a new KW V3 kit just hoping it'd fit... but haven't had the time to install for a few months.. =/ I guess this is good to know before I attempt to change it out.. haha maybe coilovers in the front and just springs in the back?
Old Apr 17, 2010 | 05:08 PM
wakeboardr116's Avatar
wakeboardr116
That might actually be good then since some people say the Eibachs aren't low enough in the rear.
Redfire32
Oct 1, 2015 04:49 PM
Mattlorentzoe
Sep 20, 2015 09:51 AM
xpcgamer
Sep 7, 2015 07:10 PM
Redfire32
Aug 11, 2015 09:05 AM
