Same brakes as Z?
Old Mar 26, 2010 | 08:38 PM
15951's Avatar
15951
Same brakes as Z?
I was reading through the February C&D, and there's an annual comparison test in there for track times for all "new" (updated) cars. The 370Z had a catastrophic brake failure and crashed into a wall. In a sidebar on the same page, it's reported that Nissan admitted that the brake pads fitted to the car were intended to reduce noise and dust at the cost of performance. As a result, they are selling a more aggressive brake pad as a dealer installed option for track use.
Do our cars have the same system as the Z? They mentioned 4 pots up front and 2 pots out back, and I can't help but note that Infiniti is selling an r-spec pad for the G. I wonder if the stock pads on our cars are also prone to failure if the car is tracked.
Just a topic for discussion, assuming this isn't a repost.
Old Mar 26, 2010 | 08:43 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
Theres another thread about our brakes prematurely wearing out the front rotors. I guess there's a part that the dealer will replace to let the brakes cool, preventing the warping of the front rotors.
Old Mar 29, 2010 | 05:08 PM
soundmike's Avatar
soundmike
I wouldn't call it a failure per se since the OEM pads would then be performing outside of its design specifications. The same way that track pads are pretty much useless for Daily Driving (DD) -- they're great pads, but they "fail" on public roads because it's outside their specifications. (i.e. needs a good bit of heat for them to work optimally, noisy, dusty, etc.)
If you intend to track your car, dedicated track pads are always a good bet, or at least more aggressive ones.
Kojack
Oct 9, 2015 05:53 PM
Mattimus
Oct 4, 2015 01:33 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
