H&r springs and spacers
Old Oct 29, 2009 | 09:27 AM
AlphaG's Avatar
AlphaG
Thanks...
Old Oct 29, 2009 | 01:20 PM
HamstersG's Avatar
HamstersG
Agree. And depending on what you set your rear camber at, you may get fender lining or bumper bracket rubbing (I did), but easily fixed with some trimming most can do themselves. This thread tells you how. https://www.myg37.com/forums/wheels-...-solution.html
Originally Posted by Kidcane
With the H&R's you will definitely want a camber kit and dont go more than 15mm on the spacers or you will run in to rubbing issues.
Old Oct 29, 2009 | 09:06 PM
maxipad96's Avatar
maxipad96
I have h&r. No need for the front camber kit. My fronts although out of spec wore fine. Rears camber kit is a must. Spacers well I'm about to go super aggresive with so I'll let youknow.
Old Oct 29, 2009 | 09:39 PM
burton08's Avatar
burton08
hmm... i have to disagree about not needing a front camber kit. i have h&r springs, and although the wear is not as bad as the back, i would recommend buying a front camber kit. half of my front tires are like slicks, no tread left whatsoever, while the other half looks fine.
dedmanchan
Sep 25, 2015 02:25 PM
TheIvoryG
Sep 23, 2015 02:06 AM
nbast
Sep 14, 2015 12:39 PM
si_driver
Sep 13, 2015 12:04 PM
