Help Stoptech Screws are broken or the caliper are!
Old Oct 1, 2009 | 08:32 PM
  #61
jnguyen's Avatar
jnguyen
Originally Posted by Igor@180Custom
Looks like you rushed for no reason... I assumed you were going to HIN in Dallas? Yeah.... it's canceled.
Nah import face off baton rouge October 4th and hin baton rougr October 9th
EDIT: WTF! HIN has been cancelled for the rest of the year except for Cali shows. At least Import Face Off is still on
Old Oct 22, 2009 | 01:46 PM
  #62
M45Owner's Avatar
M45Owner
What every happened to this problem? Did you just go with the new calipers or did you find out why the line was loose?
Old Oct 22, 2009 | 01:48 PM
  #63
jnguyen's Avatar
jnguyen
Sold the goodridge lines and went with stoptech. The stoptech work fine.
Also bought new calipers
Old Oct 22, 2009 | 01:56 PM
  #64
M45Owner's Avatar
M45Owner
So you don't know if the stoptech lines would of worked with the original BBK you were having issues with? Good thing I just read this thread cause I just ordered brake lines for my car a few days ago and was thinking about getting the goodridge set. Good thing I didn't get those.
Old Oct 22, 2009 | 02:04 PM
  #65
jnguyen's Avatar
jnguyen
The stoptech work with the original and the new one
The goodridge didn't work with the original or the new one or my friends caliper.
I try the goodridge on 3 sets and none of them work.
Old Oct 22, 2009 | 05:35 PM
  #66
ucla bruin's Avatar
ucla bruin
Crazy stuff, glad it worked out for you in the end. What did you do with your messed up calipers? I'm assuming they aren't usable anymore?
__________________
Old Oct 22, 2009 | 06:53 PM
  #67
jnguyen's Avatar
jnguyen
They are still usable actually. They just require different bolts that are bolt from napa.
What I did was install a helicoil in it. Which basically looks like a spring. You spin in inside the old tread and the helicoil use itself as a new tread. I bought a new bolt and cut it to the same size as the OEM bolts.
I'm just keep it the old ones though and have it for display or throw it away.
Old Oct 22, 2009 | 07:02 PM
  #68
ucla bruin's Avatar
ucla bruin
Let me know if you're gonna throw it away
__________________
Old Oct 22, 2009 | 07:08 PM
  #69
jnguyen's Avatar
jnguyen
Well I only have two calipers on me. I don't have all four. I was thinking of just giving the fronts to Mike and throwing away the backing.
Old Oct 22, 2009 | 08:35 PM
  #70
ucla bruin's Avatar
ucla bruin
I just need 1 front
__________________
Old Oct 22, 2009 | 09:25 PM
  #71
jnguyen's Avatar
jnguyen
which side? I only have one driver I think.
Old Oct 23, 2009 | 01:31 AM
  #72
ucla bruin's Avatar
ucla bruin
Either side. Only if you were gonna toss it, I can put it to some use. If it works out, you'll get a free one.
__________________
Old Oct 23, 2009 | 01:40 AM
  #73
jnguyen's Avatar
jnguyen
Yeah i'm tossing it out.
Old Oct 23, 2009 | 01:44 AM
  #74
ucla bruin's Avatar
ucla bruin
Want to send it to me, please? Let me know how much.
__________________
Old Mar 31, 2013 | 01:32 PM
  #75
OMG35S's Avatar
OMG35S
Bumping an old thread because I think I'm about to buy Goodridge lines since they are probably the best brake lines out in the market.
I think I know what went here. I've been researching about what lines my car needs in order to work with the Akebono upgrade.
Info on my car:
2007 Infiniti G35 Sport 6mt
(Same brakes as a non-sport g37 coupe) - (Someone mentioned that the non-sport sedans have even smaller brakes than the non-sport coupes)
Like I mentioned before my car and non-sport coupes share the same brakes. I want to upgrade my brakes to the BBK Akebono's.
Goodridge offers two different sets of brake lines for our cars:
Non-Sport Models # GOOD22034
Goodridge Gstop Stainless Steel Brakeline Kits 22034 GOOD22034 | STILLEN
Sport Models # GOOD22075
Goodridge Gstop Stainless Steel Brakeline Kits - Uncoated - Sport Models w/Akebo | STILLEN
I believe that the main differences in the kit is the obvious additional line for the non-sport kits AND the BANJO Bolts needed for the Akebono Caliper which is different than the non-sport calipers.
In my opinion you should have ordered the Goodridge Akebono Sport Brake Lines instead of the ones for the non-sport.
My only issue is the extra two brake lines that are meant for the front of the car that are used in the non-sport models. Are these two brake lines not needed if I were to upgrade to Akebono BBK?
37
Oct 17, 2020 11:12 AM
delfinparis
Nov 16, 2015 02:26 PM
EnYcee-G
Oct 4, 2015 09:27 PM
Jonesmeister11
Sep 27, 2015 08:28 PM
