PAinting my calipers HELP!
Old Jun 7, 2009 | 05:08 PM
w0ady's Avatar
w0ady
what about the caliper seals? id be worried about painting with them still installed. also, do you do any sort of sanding/scrubbing to prep the surface for paint?
Old Jun 8, 2009 | 08:12 AM
soundmike's Avatar
soundmike
Originally Posted by speedracer g37
really? you're telling me a can of duplicolor off the shelf has higher temp rating than powdercoating that cures at 375 to 400 degrees? o.k., sure. and its more durable too i guess.
Brake caliper paint can withstand up to 900 degrees of intermittent heat, if you use high heat paint (like i did), it goes up to 1,200 degrees.
G2 Caliper paints can also withstand up to (IIRC) 950 degrees of intermittent heat.
As far as durability goes, it depends on your prep. On my old car, the paint stayed on the calipers for 80k miles (until i sold it).
GeezerB
Car Care & Detailing
12
Jan 23, 2017 07:00 AM
ck1109
Oct 15, 2015 11:06 PM
EnYcee-G
Oct 4, 2015 09:27 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
Chris_M
Sep 25, 2015 08:38 PM
