Akebono calipers
Old May 6, 2009 | 02:55 PM
delion21's Avatar
delion21
Akebono calipers
I have an 08 Journey Coupe and I wanted to know if the Akebono calipers will fit on my rotors or would I have to get larger rotors?
Anybody??
Old May 6, 2009 | 02:57 PM
C@ciQ's Avatar
C@ciQ
You need new rotors!!!
Old May 6, 2009 | 03:04 PM
delion21's Avatar
delion21
Damn...I was afraid to hear that. Riverside sells the calipers for $229 a piece and stoptech rotors for $234. I can put together a front bbk kit for about $700...hmmm not bad instead of paying $1900 just to get the rear calipers which I dont really need.
Old May 6, 2009 | 03:35 PM
Triple_X's Avatar
Triple_X
buy the rotora rotors from andy@hpauto and powder coat your calipers....gets rid of the rusty oem look and costs alot less
Old May 6, 2009 | 04:19 PM
SOLISIMO's Avatar
SOLISIMO
I though we had Brembos?
Old May 6, 2009 | 09:19 PM
alexdee's Avatar
alexdee
Isn't it 1500 for a whole set? Not just the rears?
Old May 7, 2009 | 10:57 AM
delion21's Avatar
delion21
Riverside has the set for $1900 front and rear calipers, froont rotors and brake fluid.
Honestly I dont need the rear as 80% of your brakes are up front. If I can put together a kit for $700 that is a deal excluding the rear.
Old May 8, 2009 | 09:22 AM
soundmike's Avatar
soundmike
Don't forget the clips, pins and pads.
The $1900 kit from RI includes *everything*... bolts, dust shields, brake lines, F+R rotors, F+R pads, F+R clips/pins, F+R calipers, fluid, etc...
If you just want the basic components, forego replacing the dust shields and re-using your existing bolts. This is really all you need.
If you sourced these out yourself, it comes out to a little under $1,400.
Old May 8, 2009 | 09:23 AM
soundmike's Avatar
soundmike
I don't know about the 37's, but the 35's apply quite a bit more pressure to the rear brakes than they do to the front.
Then, you also have to consider how much just replacing the front brakes will affect your brake-bias.
Old May 8, 2009 | 01:38 PM
twin001's Avatar
twin001
have fun removing and replacing the dust shields....I started going down that path and eventually got pissed and just cut them out as much as I could.
Old May 9, 2009 | 01:05 PM
jhurst's Avatar
jhurst
I know I will probably get kicked out of here but I am selling a front set of Akebono calipers and rotors, along with the OEM pads (and all hardware you need). PM me for info/pics. (I'm a G35 owner, thus 1st post on G37 forum)
ck1109
Oct 15, 2015 11:06 PM
faze2988
Oct 7, 2015 12:05 AM
EnYcee-G
Oct 4, 2015 09:27 PM
VIVID
Sep 27, 2015 09:45 AM
Allboutcali
Sep 26, 2015 03:43 PM
