View Poll Results: What is your sway setting?
Softest
4.35%
Medium
12
52.17%
Stiffest
43.48%
Voters: 23. You may not vote on this poll
Hotchkis Sway settings
Old Apr 25, 2009 | 12:12 AM
  #31
JLai's Avatar
JLai
Originally Posted by SilverBullet
I like to hear more from those who have the stiffest setting on Hotchkis sways. How do you like it? If you had it on medium setting and then switched, what do you think of the difference? Is there a lot of oversteer? How is the handling on the twisties?
x2. I'm in debate b/t medium and stiffest. They're sitting in my living room, waiting for the Eibachs to do all at once.
Old Apr 25, 2009 | 12:15 AM
  #32
wakeboardr116's Avatar
wakeboardr116
Well I decided to order these over the stillens. They should be getting here some time next week and i will be installing them over the weekend. Then next sunday I am doing a track event and will test them out. I'm thinking I will set hem on the middle setting first and see how they feel on the first run. Then for the second run i will move them to the stiffest one and try it again. I'll be sure to let you guys know how it goes.
Old Apr 25, 2009 | 07:56 PM
  #33
kkokko's Avatar
kkokko
I got my grounding kit and hotchkis installed today =) on setting 2, with a non sport g37, no springs yet.. havent got a chance to drive hard with them on yet but will soon =)
Old Apr 25, 2009 | 08:57 PM
  #34
SubSurface's Avatar
SubSurface
Originally Posted by splitmx
So you can use the stock endlinks with these?
Yep, straight forward and relatively simple swap out with stock parts. See Hotchkis F&R Sway bar install in the DIY section of the Forum.
Old Apr 29, 2009 | 11:14 AM
  #35
Triple_X's Avatar
Triple_X
old message was answered
Old Apr 29, 2009 | 10:19 PM
  #36
ratso000's Avatar
ratso000
I have stock 2008 non S Journey and have them set to medium (middle hole in rear sway bar) I find the car handles very well.I do hear some noise when on really bumpy roads and going over speed bumps at low speeds.The balance of the car seems very good at high speeds and agressive driving on the interstates. For street use I will keep the current set up, especially since the roads in Louisiana are generally in poor condition.
Old Apr 29, 2009 | 11:23 PM
  #37
kkokko's Avatar
kkokko
what kind of sounds do u hear did u see my thread on my hotchkis noise?
Old Apr 29, 2009 | 11:24 PM
  #38
kkokko's Avatar
kkokko
https://www.myg37.com/forums/brakes-...rom-front.html
Old Apr 29, 2009 | 11:36 PM
  #39
ratso000's Avatar
ratso000
slight flexing noise ,low pitch on speed bumps , washboard on worn intersections usually with a turn you feel a real harsh ride and some rattling. I beleve the sway bars stiffen up the car so much that this is the trade off for great handling.I have had several 60s muscle cars that I added sway bars to and experienced the same types of noises,they had the early versions of polyurathene bushings that where not lubricated with special greases.My experience is as they wear in over time they get a bit quieter.
Old Apr 29, 2009 | 11:38 PM
  #40
Originally Posted by ratso000
slight flexing noise ,low pitch on speed bumps , washboard on worn intersections usually with a turn you feel a real harsh ride and some rattling. I beleve the sway bars stiffen up the car so much that this is the trade off for great handling.I have had several 60s muscle cars that I added sway bars to and experienced the same types of noises,they had the early versions of polyurathene bushings that where not lubricated with special greases.My experience is as they wear in over time the get a bit quieter.
Not enough silicone grease is probably your issue. Grease them until it starts squeezing out of the bushing and I bet your noises will stop.
Old Apr 29, 2009 | 11:39 PM
  #41
ratso000's Avatar
ratso000
yes i read your threads, it sounds like some loose parts from your discription
Old Apr 30, 2009 | 01:52 AM
  #42
kkokko's Avatar
kkokko
betty, did you just use the supplied greasing ? or did you add even more?
kavcheung
Jan 22, 2016 02:40 PM
kcg37
Sep 15, 2015 11:21 AM
