Camer adjustment on new FM platform?
Old Oct 6, 2007 | 09:49 PM
jwfisher's Avatar
jwfisher
One of the worst problems on the old FM platform - aka Z and the old G357 coupe, was lack of factory provision for front camber adjustment. And the rear.
Yea, there are aftermarket arms. But it should have had that from the factory.
Does the new FM platform fix this problem? Anybody got any detailed pics of the front suspension?
Old Oct 22, 2007 | 09:58 PM
bocatrip's Avatar
bocatrip
I'm going to make the assumption that since the 07 G35 sedan has no camber adjustment, the G37 most probably has none either.
Old Oct 27, 2007 | 07:27 PM
SLaPiNFuNK's Avatar
SLaPiNFuNK
V36 & CV36 do not have any front camber adjustment...
Rear set up is very similar except some arms are lighter weight now...
The front upper A-Arm & Spindle are a different design now, the ball joint now is clamped onto by the spingle...
different supension arm set up up front as well...
Old Oct 28, 2007 | 02:44 PM
bocatrip's Avatar
bocatrip
I wonder if the new setup will be less susceptible to feathering and will hold up longer without needing constant adjustments for going out of alignment.
Old Oct 28, 2007 | 02:52 PM
IP37's Avatar
IP37
few suspension pictures..
eljoker
Future Models
19
May 30, 2022 11:48 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
4DRZ
Nov 7, 2015 08:32 PM
moteel
Site Feedback & Suggestions
Sep 18, 2015 08:23 PM
