G37x sedan low beam wiring
Old Oct 27, 2023 | 01:39 PM
Thedhc's Avatar
Thedhc
Hello!
I am preparing to modify my headlights and add panamera shrouds as DRL.
The shrouds have a wire to connect to the low beam to dim when low beam is enabled.
Does anyone know which wire at the headlight connector controls the low beam? Or should i connect it to the parking light instead? I believe that one comes on together with low beam.
And since i got AFS, can i even add another shroud to projector? Im not sure what the turning part is of the AFS system?
Old Nov 2, 2023 | 03:57 PM
Thedhc's Avatar
Thedhc
Ive figured the wiring out, going on park light.
What about the afs, any ideas?
Old Nov 4, 2023 | 05:30 AM
Thedhc's Avatar
Thedhc
I found this thread; https://www.myg37.com/forums/body-in...eadlights.html
Seems like the actual projector moves, so i should be fine with another shroud over it.
Thanks i will go ahead with the change next spring.
Whiterocket
Jan 15, 2020 09:26 PM
willstophe
General Tech Questions
May 12, 2017 08:08 PM
GoFightNguyen
26
Mar 21, 2016 09:29 PM
Samer Serhan
Aug 5, 2013 09:26 PM
romeostylez13
Aug 9, 2009 06:05 PM
