Help Instrument cluster resets each time I turn car off/on
Old Jul 21, 2023 | 12:29 AM
Ander's Avatar
Ander
Hello, so recently I decided to install an aftermarket interface for CarPlay on my 2009 G37s Sedan. So I mixed up the wiring for the stereo to the AC amp. I have since then returned everything back to normal and removed the aftermarket parts. I burned a fuse and had lost the backlighting to the stereo buttons, climate buttons, and analog clock. I assumed i burned the ac amp box because after replacing Fuse 53, the fuse blew again. I just replaced the AC amp from another 2009 G37 sedan same P/N and everything. My AC works, my car turns on, and the lights are all on again and the fuse hasn’t blown. However everytime I turn the car off and turn it back on my AC resets to off and 75 degrees and my instrument cluster resets to 0 trip, no MPG and no trip timer etc. Any help would be appreciated as I’m stumped. I know it’s not a big issue but I have a remote start and here in AZ I like to cool my car down before getting in.
Old Jul 21, 2023 | 09:26 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Check fuse #11 in the driver-side fuse block. Should be marked "METER (BAT)." This is the circuit that provides power to the KAM function for the cluster and the amp.
Old Jul 21, 2023 | 03:43 PM
Ander's Avatar
Ander
Update
Yes, Thank you! I checked the #11 Fuse and it was blown, I replaced it and everything is working correctly now !
Jchappell22
Dec 17, 2022 10:17 AM
Juelz86g37s2012
General Tech Questions
May 29, 2019 09:49 AM
HotSawce
Apr 3, 2017 08:54 AM
JunioRs_G
Apr 19, 2013 10:30 AM
jking
Jun 15, 2012 02:35 PM
