Spyder gtr headlights problem
Old Dec 26, 2020 | 08:48 AM
BillyTheMan's Avatar
BillyTheMan
I bought the spyder gtr style headlights probably 6 months ago and just yesterday I noticed on the drivers side the fancy part that also uses the turn signal light works, I don't know if there's a name for that part. But the 2 bulbs below don't. Brights work fine. I found a picture of some headlights they might for a 2 door I don't know but I circled the part that's not working. Is it a bulb? Loose connection? I'm not real familiar with electronics or headlights.
Old Dec 26, 2020 | 10:31 AM
ILM-NC G37S's Avatar
ILM-NC G37S
KEEP IN MIND I AM ONLY GUESSING HERE AS I AM NOT FAMILIAR WITH THESE UNITS!!!:
From what I can surmise, the circled part in your photo is for the hi-beam headlights. OEM headlights use the same projector for LO & HI beams. It seems these things separate the beams to different projectors.
Also, it appears that these units use Halogen bulbs for the hi-beams as opposed to the Xenon bulbs for the HID lo-beam. Halogen bulbs typically have a shorter life than Xenon's.
Here's what I found:
It never hurts to check the bulbs. But, if that still does not solve the problem, I would contact the vendor you purchased them from and/or the mechanic who installed them (unless self-installed) and see what they advise. There may still be a warranty in force.
Again, I'm flying blind here. Hope some of this helps.
Old Dec 26, 2020 | 11:08 AM
BillyTheMan
I did install myself. Come to think of it when I first got them the drivers side would flicker when I hit a bump in the road. I wonder if whatever connection was loose came completely out. I tried hitting the light and moving it around as much as possible without completely pulling it out, didn't come back on.
Old Dec 26, 2020 | 11:47 AM
ILM-NC G37S
Could be a bulb issue. Could be a wiring issue. Best advice, pull the unit out and start checking.
Old Dec 27, 2020 | 08:58 AM
slawek65's Avatar
slawek65
Two outside projectors are for low beam ( HID D2S bulb ) Yes, two projectors for one bulb. Inside projector is for high beam and use halogen bulb. You have problem with HID bulb, ballast, connection ....
Old Jan 10, 2021 | 06:03 PM
takemorepills's Avatar
takemorepills
These use the OEM ballast and OEM bulb to ballast harness?
Old Jan 10, 2021 | 06:07 PM
BillyTheMan
I finally pulled the headlight out. Didn't see any bad connections or loose wires or exposed wires. Ordered a new bulb for the hell of it. If that doesn't work I'll contact the manufacturer.
Old Jan 10, 2021 | 06:32 PM
takemorepills
Does the low beam use the OEM ballast and OEM connector? If so, hopefully a new bulb fixes it. Use the OEM 85122+ for reliability.
If you continue to have low beam issues, and the low beam system is OEM, you'll need to look deeper and make sure the OEM stuff is correctly installed.
BTW, how do you like the output of these lights? Are they as good as stock for low beam?
Old Jan 10, 2021 | 08:28 PM
BillyTheMan
I know it uses the oem ballast, I'm not sure about connector. It's been a while since I installed them, I know I didn't have to do any wiring. As far as being better than oem lights I just figured out how to adjust the projector direction yesterday so when I get the light fixed I'll let you know. They are pointed too far down right now.
Old Jan 19, 2021 | 03:59 PM
BillyTheMan
Well I haven't figured it out so I called spyder and they said take up the warranty with the vendor. So after a few back and forth emails with carid.com they are going to look into and I should expect a solution in 3 to 5 days.
Old Apr 26, 2021 | 04:53 PM
Kimtej Gill's Avatar
Kimtej Gill
Did you get it solved? Have the same problem
I bought the same lights and they are doing the same thing. I was bout to replace the ballast. Did you get yours resolved? What was the issue?
Old Apr 26, 2021 | 11:51 PM
BillyTheMan
Well spyder never answered carid so I never got a replacement from either. The only thing I could find by looking at was part of the bulb socket that goes into the headlight was broke off. So the bulb itself wasn't sealed right but the wire connection appeared fine so you'd think it would work still. Anyway I crashed my g37 on the highway back in February and both headlights were smashed anyway. Front body was pretty smashed, I could have driven it home if it wasn't stuck still ran fine. Ended up selling to a friend and getting an 09 SRT8 charger.
Old May 15, 2021 | 10:33 AM
Udaman's Avatar
Udaman
From: Garland,Texas, you know, the place they mention at the beginning of Zombieland.
Spyder headlights
It looks like Spyder may have addressed this issue. These aren’t available at the moment. All current orders for these lights are preorders that will not ship until Aug. and according to the description, they now use Xenon bulbs.
Nyzflyyguy
Mar 9, 2021 10:23 AM
SLOWG37xS
Jul 12, 2020 10:02 PM
Vq_Jordy
Sep 16, 2019 12:15 PM
SLOWG37xS
Aug 22, 2019 07:14 PM
Jo3nahxS
Oct 18, 2018 11:10 AM
