Heard scraping sound going above a speed bump and noticed lowered shield plate.
Old Dec 8, 2020 | 10:16 PM
MStrike's Avatar
MStrike
Hey, I went over a speed bump and heard a scraping sound. When I got home and checked it out, I noticed that the front of the shield plate was messed up, specifically, two bolts were detached and one was missing. I tried putting the bolts back but they wouldn't stick. I did some research and saw that they attach to a metal clip, but if the plastic goes away with it then you need to use a different approach. Does anyone have any recommendations on how to tackle it?
Old Dec 8, 2020 | 11:03 PM
JSolo's Avatar
JSolo
Just say no!!!!!
JBweld... great stuff.
Almost deleted your post due to the embedded link. Rather than embedding it, indicate there's a link to the video showing the issue.
Ooops. disregard the edit above I made no changes. Meant to edit my own post.
Old Dec 8, 2020 | 11:15 PM
MStrike's Avatar
MStrike
Should I simply put some on the lining and disregard the front bolts? Also, how easily removable is it, for example, when doing oil changes? Thanks for the suggestion.
Old Dec 8, 2020 | 11:18 PM
JSolo's Avatar
JSolo
Just say no!!!!!
JB weld is a 2 part epoxy of sorts. It's relatively permanent but can be ground down with a dremel or similar once dried. You could try rebuilding this part - https://i.imgur.com/waOmG46.png with it.
Ash Yalew
General Tech Questions
Feb 8, 2018 09:49 PM
Lt8Che
Nov 17, 2015 12:14 PM
Ihtbealexxx
Aug 23, 2015 01:58 PM
Kevalteam
Apr 23, 2014 10:05 AM
djkymar
47
Apr 13, 2008 02:36 PM
