Took out 4 sunroof firewalls, cut off baffle and added zip tie, but still leaks
Old Oct 31, 2020 | 10:04 AM
MStrike's Avatar
MStrike
For the passenger side you will need:
- one (1) ⅜" barb coupling;
- one (1) ½" x ½" x ⅜" barb T-fitting;
- ⅜" ID tubing;
-5 zip ties (used as clanps).
I used brass fittings but you can use whichever material you prefer.
When you lift up the passenger carpet you will see the AC evaporator drain tube. It would not hurt to add a little silicone to the grommet where the tube passes through the floor.
Here is a alternative method to address the driver side front drain.
Quick question to make sure I'm getting everything right: obviously the 3/8 tubing gets attached to the sunroof drain, which then gets attached to the 3/8 of the T splitter. Then, the ac line is attached to the 1/2 end while the other 1/2 end goes to the floor plug, or does that last end gets attached to the barb coupling (what purpose does this serve btw)?
Also, the driver's side procedure isn't loading.
I did notice that yesterday, on the driver's side only tho, that while my A pillars were off this was happening whenever I poured water onto the sunroof drain: https://streamable.com/c8baxs. Do you think that this would mean there's a problem with the driver's hose or the sunroof pan gasket?
Old Oct 31, 2020 | 10:55 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Re: the passenger side drain:
I cut the AC drain line just before the grommet in the floorpan and spliced in the t-fitting. Then, the ⅜" tube (from the sunroof) goes to the t-fitting. It should look similar to what member Jesse123456 posted:
Only difference was that I ran everything under the insulation to keep it neat.
As for the left side, you will have to check that the hose itself is still attached to the upper sunroof drain. You will likely have to lower the headliner slightly to check. You shouldn't have any water dripping on that airbag module.
Old Oct 31, 2020 | 11:34 AM
MStrike's Avatar
MStrike
Oh ok, I can see how it's done. Yeah that leaking looked a bit suspect because it didn't happen on the passenger side. Do you think if I use some angle nosed pliers I can try to push it in without taking off the headliner?
Also, for the driver's side, I was also referencimg the link that you initially posted (for the routing) as not loading. Thanks.
Old Oct 31, 2020 | 12:08 PM
ILM-NC G37S
Here is the link to a alternative remedy for the driver side leak. Member 03Mach69Mach opted to drill a hole in the floor (near the dead pedal) and run the drain tube that way Driver Side Floor Drain. I will likely go that route as I prefer all drains to exit to the ground and have zero potential for water to get near any electronics or other vital components.
Old Nov 4, 2020 | 06:53 PM
MStrike's Avatar
MStrike
Hey, I made an updated post if you don't mind checking it out!
901G
General Tech Questions
Nov 5, 2021 08:23 AM
ctng37
31
Mar 11, 2021 03:55 PM
Conboss
14
May 30, 2020 08:13 PM
BillyTheMan
May 19, 2020 12:20 AM
Npg96
Apr 11, 2019 02:48 PM
