Airbag light won't turn off
Old Dec 22, 2019 | 10:09 PM
Civil's Avatar
Civil
I took out my passenger and driver seat and put in some recaro buckets and I tried doing the 4 ignition switch method, bit the light remains on. Can I go and get it clear coded or do I have to do something else
Old Dec 23, 2019 | 04:26 PM
telcoman's Avatar
telcoman
If you didn't disconnect your battery prior to doing any work related to air bags you may have damaged the module?
http://www.nicoclub.com/FSM/G35/Sedan/2008/SRC.pdf
SRS AIR BAG WARNING LAMP DOES NOT TURN OFF Diagnosis Procedure INFOID:00000000019079421.CHECK FRONT AIR BAG MODULE Check the deployment of front air bag module.Is air bag module deployed?YES>> Refer to SRC-129 or SRC-131, "Diagnosis Procedure".NO>> GO TO 2.2.CHECK AIR BAG FUSE Check the air bag fuse. Refer to PG-95, "Fuse and Fusible Link Arrangement".Is 10A fuse [No.2, located in fuse block (J/B)] normal?YES>> GO TO 4.NO>> GO TO 3.3.CHECK AIR BAG FUSE AGAINReplace air bag fuse and turn ignition switch ON.Did the air bag fuse blow again?YES>> Repair or replace main harness.NO>>INSPECTION END4.CHECK DIAGNOSIS SENSOR UNIT Check the screen of CONSULT-III.Is the inspection result normal?YES>> GO TO 5.NO>> Replace diagnosis sensor unit (ACU). Refer to SR-16, "Exploded View".5.CHECK HARNESS CONNECTIONCheck harness connection between air bag warning lamp and diagnosis sensor unit.Is the inspection result normal?YES>> Check the intermittent incident. Refer to GI-39, "Intermittent Incident".NO>> Replace wiring harness connector
Infinibini
General Tech Questions
Aug 2, 2024 01:21 PM
lumpyg37
Oct 9, 2022 02:59 PM
kluthage421
Jan 29, 2018 09:40 PM
*ICE*
Nov 30, 2015 05:39 PM
Used2BaHEMI
Mar 3, 2015 12:08 AM
