My tail lights went out help me!
Old Dec 23, 2019 | 07:13 PM
youngbeats4135's Avatar
youngbeats4135
I have a 2011 g37. So one day one of my coworkers told me my tail lights was out but I wasn’t really listening because it was a old lady but now one of my friends told me then another co worker told me about them so I listened I check online about the situation but mainly they say it’s a fuse problem Check the fuse but it didn’t looked burned or anything so I just changed it anyway to double check but it’s still not working so idk what to do please help. Also I recently just installed 2 12 kickers comp c but I don’t think that would cause my tail lights to go out either.
Old Dec 23, 2019 | 07:17 PM
CubanDre's Avatar
CubanDre
Did you try swapping bulbs? Did you wire the kicker yourself? Disconnect it and see if your lights come back. Let us know
Old Dec 23, 2019 | 07:22 PM
youngbeats4135
I didn’t change the bulbs out Bc the brake lights still work and no I didn’t do it myself I took it to professionals to install it for me but they turned off way before I even got them installed
Old Dec 24, 2019 | 07:39 AM
telcoman's Avatar
telcoman
Have you ever considered reading the FSM?
http://www.nicoclub.com/FSM/G37/Sedan/2011/EXL.pdf
System DescriptionINFOID:0000000006209405OUTLINEParking, license plate, side marker and tail lamps are controlled by combination switch reading function andheadlamp control function of BCM, and relay control function of IPDM E/R.PARKING, LICENSE PLATE, SIDE MARKER AND TAIL LAMPS OPERATION• BCM detects the combination switch condition by the combination switch reading function.• BCM transmits the position light request signal to IPDM E/R with CAN communication according to the ON/OFF condition of the parking, license plate, side marker and tail lamps.Parking, license plate, side marker and tail lamps ON condition- Lighting switch 1ST- Lighting switch 2ND- Lighting switch AUTO, and the auto light function ON judgment (with auto light system)• IPDM E/R turns the integrated tail lamp relay ON and turns the parking lamp, license plate, side marker an dtail lamps ON according to the position light request signal.
Are you sure you checked the correct fuses?
Use your multimeter!
Old Dec 25, 2019 | 10:28 PM
youngbeats4135
I fixed it
Okay so I found the problem my red and black wires was touching each other on my license plate. Basically if they touch they instantly blow ur tail light fuse well that’s what it did for me anyway.
Aaron.g37
May 20, 2026 09:03 AM
Bob1906
Mar 17, 2018 06:20 PM
staskz
May 27, 2015 04:06 PM
NiTeHawKPwNeD
60
Apr 16, 2013 01:28 AM
DeepRumble
Jan 31, 2012 08:59 PM
