Help G37 Intermittent DRL and Dimmed Head Lights
Old Jul 30, 2019 | 01:15 AM
wowow's Avatar
wowow
The DRL on the passenger side comes on very intermittently (90% off), and I've had the bulb replaced multiple times with the same results. Now the passenger side headlight is also noticeably dimmer than the same xenon light on driver side.
Picture: https://imgur.com/a/4fzvZqC
Any idea what is going on? How can I fix this?
Old Jul 30, 2019 | 02:48 PM
Surfnazi's Avatar
Surfnazi
Check ballast and ignitor swap sides and see if it does same when you swap then. Also check grounding straps and that battery cells have water if low add distilled water
nolsg37
May 2, 2016 08:22 PM
MEH2013G37
Sep 24, 2015 08:37 AM
romansiny
Jul 7, 2010 12:55 PM
