G37 window stuck when hot
Old Jun 11, 2019 | 03:21 PM
VetteLT193's Avatar
VetteLT193
I have a 2013 G37. For many months now when the car is hot and I open the windows from the remote the driver's rear window would stay up. I thought it was a software bug and didn't do anything about it. Yesterday I didn't use the remote and just got in the car... tried rolling down all 4 windows and all I got out of the rear one was a 'click' sound. I tried it a few times, no luck. After the car cooled down about a half hour later I tried again and the window works fine.
Any thoughts? It's such a strange problem I don't quite know where to start.
Old Jun 11, 2019 | 03:44 PM
Baadnewsburr's Avatar
Baadnewsburr
It may be a failing actuator, its not unheard of that one or two of them will go on these cars...
Old Jun 11, 2019 | 06:15 PM
PNW_IPL's Avatar
PNW_IPL
My passenger side is doing the same. Haven't found a fix yet. Probably what hash said.
Old Jun 11, 2019 | 07:59 PM
VetteLT193's Avatar
VetteLT193
Is the actuator the same thing as the motor?
Car has been nearly flawless otherwise. Only other issue ever was a leaking sunroof drain. in 6 years and 65k I have changed the basics (oil, filters) 1 set of tires, rear pads, and 1 battery. Car has been virtually bulletproof which is why this small issue is almost shocking!
Old Jun 12, 2019 | 09:34 AM
Baadnewsburr
yup same thing AFAIK.
Its hit or miss with these sometimes, just be gald it nothing bigger...when you open up the door see if theres corrosion on the motors/actuators...they may just be victims of the sunroof leak issue had...
ebay and scrap yards have tons of these btw as these are commonly replaced parts on cars of all makes and models... the prices aren't too bad...
kOrE
Aug 9, 2016 10:55 AM
xxcomnupxx
Aug 25, 2014 05:28 PM
myk1013
May 14, 2011 02:37 PM
08Gsmith25
May 12, 2010 12:57 PM
