Help stuck window glass
Old May 9, 2011 | 07:43 PM
myk1013's Avatar
myk1013
stuck window glass
Ok, before you say all I need to do is RESET the window regulator motor.... Let me say now that I have tried that and no luck.
Basically, my driver side window will not roll down when the door is opened. The glass is stuck in it's highest or in the door closed position. I had to drive home with the door cracked slightly open because the door cant be closed with the glass stuck up there.
The passenger side works fine.
Anyone have any idea whats wrong??
Old May 9, 2011 | 07:47 PM
Modme's Avatar
Modme
That's not something needs regulator resetting. Sounds like your window motor is broken.
Normally, the car window will slide down every time you open the door, until it reaches the very bottom. That's when a simple reset will fix the problem.
In your case, it's either a broken motor or a wire is disconnected.
Old May 9, 2011 | 08:36 PM
myk1013's Avatar
myk1013
Thats what i was thinking man. thanks.
Old May 14, 2011 | 02:37 PM
myk1013's Avatar
myk1013
UPDATE**
Dealer fixed window issue, works fine now. It was the switch that was malfunctoning.
They also ordered new washi door pulls and that washi trim around the shifter for me. All under warranty.
RexHavoc
Oct 2, 2015 11:47 AM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
CiViCKiDD
Sep 24, 2015 10:47 AM
Wreckreation
Sep 21, 2015 06:27 PM
