Turn fog lights into DRL
Old Jun 11, 2019 | 02:42 PM
Snaoum's Avatar
Snaoum
I've got a 2011 G37xS sedan and I have installed the Morimoto Fog lamps. I am interested in turning them into DRL. It is easily done by tapping into an ignition source under the hood, but what here is where I need help. I want them on anytime the car is running, but be able to turn it off and control it via the stock switch. If anyone has any ideas shoot them over. I am more than technically inclined and very knowledgeable of 12V setups.
Old Jun 11, 2019 | 02:55 PM
Snaoum's Avatar
Snaoum
I am thinking of just supplying the Fog Lamp fuse ignition power and hope the switch will continue to control it. Without schematics it hard to know without trying where in the circuit the switch resides.
Old Jun 11, 2019 | 07:22 PM
ILM-NC G37S's Avatar
ILM-NC G37S
I can help with the schematics! Here is a link to the Factory Manual for your car:
2011 G37 Sedan FSM
You will need section EXL (Exterior Lighting) and BCS (Body Control System) though I recommend downloading the whole FSM. It comes in handy.
Good luck!
Alex
Old Jun 12, 2019 | 10:02 AM
This was an easy trick with the 5th Gen Maxima, involving bypass connections at the fuse box. I've always wanted to do the same to the G.
/subbed
Slowg37
Aug 8, 2016 03:34 AM
StephenAureo
Feb 17, 2014 09:13 PM
SkylineV36
44
Jul 26, 2013 03:33 PM
zir
Apr 14, 2011 12:51 PM
