Help: Reinstalling steering wheel/airbag when reconnecting battery horn goes off
Old May 23, 2019 | 01:44 PM
GDriveAlot's Avatar
GDriveAlot
Hey guys hoping someone can help me. I finally did the steering wheel wrap mod on my car, and vinyl wrapping the trim bezel. However when I am reinstalling the airbag, it doesn't fit flush, like its not going in all the way. I don't remember if this is normal or not. However, when I reconnect the car battery, my horn starts going off. Any advice? I believe I installed everything back correctly.
Old May 23, 2019 | 01:54 PM
teahead's Avatar
teahead
If you popup off the airbag center, w/all wires still connected, does the horn STILL go off?
You got the horn wire/connection pressed somewhere.
Old May 23, 2019 | 03:20 PM
GDriveAlot's Avatar
GDriveAlot
Yes, but I figured it out at least it seems like it. I loosened the two T40 bolts with the springs underneath a little and it somehow worked. In regards to the airbag not sitting flush, is this how it is suppose to be? I should have tooken a before picture
Old May 24, 2019 | 08:47 AM
Baadnewsburr's Avatar
Baadnewsburr
this is the correct way to fix the horn issue
for the airbag not sitting flush its the same T40 bolts on the springs that determine how flush the airbag will sit...if they are all the way tight they set off the horn nonstop..too loose and the airbag wont sit flush and may even seem like its falling out...you have to loosen them evenly and only enough so that they aren't in constant contact with the copper contacts for the horn but theres still tension on the springs
Vocalvoodoo
May 24, 2018 09:26 AM
marty315
Sep 4, 2012 09:26 PM
HamstersG
33
Jun 20, 2009 08:11 PM
Stylin G
Mar 18, 2009 03:38 PM
