Airbag light flashing, can’t reset pulled code b1015
Old Jul 27, 2019 | 06:50 PM
mickeytl's Avatar
mickeytl
Is the airbag control module located underneath the dashboard or the center console?
12 Infiniti G37x
Old Oct 9, 2019 | 12:48 PM
reburke's Avatar
reburke
Hi, I have a similar problem. I have bought a used 2012 G37 Coupe with the airbag light flashing 7/1. I went to the dealership and they told me the airbag control unit is broken and told me the repair would cost around USD 2300. They also told me that the part I need to replace has code K8820JL43A. Please do you have any suggestions where is it possible to try to reset the original unit or where to find this part? If I put the code in Google it will show nearly no results. I am from Europe, Czech republic and the VIN is JN1GCBV36U0870103. I will appreciate any help. Thanks.
Old Oct 9, 2019 | 01:27 PM
Mpotros's Avatar
Mpotros
My part # provided by dealer is k8h20jk83c (2012 g37x.sedan) . I went to independent mechanic and he verified same issue and quoted similar price as dealer. Dealer price quote was $1400 USD. The part new is 1059$. However I found this part on other sites for about 700$ Also I found used ones for about 100-200$ on eBay, but those will require additional programming.
What i did was continue to nag the dealership service manager, and left them some bad reviews when I got a survey email. Bc I was upset this part shouldn’t breakdown, and cost is extreme. Anyway they covered 80% of the cost eventually after a few talks w the service manager. Also I bought the car at that dealer so that helped a bit.
If that hat isn’t an option or doesn’t work for you try finding the part online but speak to a mechanic first who can program the part, this is key!, and then install it. The reprogramming alone can cost a couple hundred dollars. But still should be cheaper than the 2300 you were quoted.
Old Oct 9, 2019 | 02:57 PM
reburke's Avatar
reburke
And that is the problem, I cannot find the part online . That's why I would like to ask whether it can or cannot be replaced with some unit with different code (that may be the same as this one, I do not know) and whether it will require some serious programing involved or pure replacement is enough.
Old Oct 10, 2019 | 12:13 PM
PNW_IPL's Avatar
PNW_IPL
2012 g37x: This happened after my battery died and I tried to jump start the car unsuccessfully. Had the battery replaced under battery warranty at pep boys and then I notice the airbag light is flashing. 1 long, 7 short. I took the car back to pepboys the next day and they ran the codes on it and got a current code for b1015. Anyone else have a similar expierence or know of this issue? I tried to reset using the on off 3x procedure and pep boys tried as well unsuccessfully.
I tried searching these forums with no luck.
Do it 4 times! Mine needed 4 times not 3!!!
Old Oct 11, 2019 | 09:51 AM
reburke's Avatar
reburke
I have disassembled the central console and the part number of my unit is really 98820-JL43A. Since this part is nearly impossible to buy second hand, I would like to ask, what is the difference between this part and part 98820-JL00A and if it is possible to put JL00A to my car. Thank you.
Old Nov 6, 2019 | 12:37 PM
bensdq's Avatar
bensdq
Originally Posted by Baadnewsburr
You probably don't have to buy a new srs module. You can probably just send it out to a third party company and get it reprogrammed/reset.
I have this same problem. Has anyone removed the sensor and sent it out? Looking for documentation on how to do it.
Old Nov 6, 2019 | 12:59 PM
reburke's Avatar
reburke
For anyone, I have finally solved the problem. There are two parallel CPU's on the board and one had short circuit. The solution was to buy new CPU directly from the factory and reprogram it. It was not easy and only one ëxpert guy in my country was able to do it. It is definitely not a solution for authorized dealership but for specialized company. Bad thing is that even the CPU was approx USD 900 from Germany but still much cheaper than new unit.
Old May 25, 2021 | 05:45 PM
max gs's Avatar
max gs
G37 b1015
I solved it for $60 really easy fix check out the video
Old Jan 15, 2023 | 02:40 PM
khopkins's Avatar
khopkins
Same Problem.
I have the same issue right now. Did you fix it?
Old Mar 24, 2025 | 07:21 AM
MARY.NISSAN's Avatar
MARY.NISSAN
Ciao,
ho lo stesso problema, ho trovato in rete diverse procedure ma non si resetta la spia airbag, puoi gentilmente indicarmi la procedura che hai usato? grazie
Old Dec 9, 2025 | 05:48 PM
gruv9873's Avatar
gruv9873
I have the same issue. Dealer has told me i need a new airbag control module and that it also will need 3 hours of programing to work with my car. After spending $2k for a new module, I do not understand why it would require 3 hours of programming. I can't imagine this is done on every new car on the manufacturing line.
Does anyone have some details on the programing required when you replace the main airbag module?
Richsedlor
Jan 21, 2019 03:00 AM
LPV36
General Tech Questions
Aug 24, 2018 08:08 AM
HarvirK
Jan 12, 2018 11:11 PM
Stone27
Apr 15, 2017 02:04 PM
defeated
Sep 3, 2012 10:46 PM
