good or bad price quoted for vinyl wrap?
Old Jan 31, 2019 | 10:14 PM
rotarymike's Avatar
rotarymike
Moderator in Moderation
Talked to a shop today about doing a chrome delete on the window trim. $150-200 depending on how hard the rear quarter window trim (the S shape) is. That seems high. Is that high? Are *they* high?
That is with using 3M or avery vinyl to match the b-pillar oem vinyl.
Old Feb 1, 2019 | 09:44 AM
Baadnewsburr's Avatar
Baadnewsburr
I don;t think thats too bad if thats labour and materials...check out the DIY on here most people do it themselves because its super easy, the way a shop would do it would probably waste a lot of material on that S shape rear quarter but it'd be much faster so the price probably covers that too. ...the materials are about $30 and its at least a few hours of labour if your do it the DIY way
Old Feb 1, 2019 | 10:05 AM
rotarymike's Avatar
rotarymike
Good to know that's a sane quote for labor and materials.
Guy said that 3M makes a chrome-delete kit now that is a roll of 2" wide matte vinyl so they don't have to waste a whole yard sheet, although he wasn't sure if he could flex it enough to do the S.
I'm not confident that I can do it well enough on the exterior to last any appreciable time. The s-shape is a concern too. I've tried tinting before, under professional guidance, and just don't have the talent for it.
I will probably be doing the inside parts; if I run into trouble I can take him the pieces I can't do. Found Avery has a brushed metal finish (like the oem one) that is black instead of pewter.
Old Feb 1, 2019 | 10:29 AM
Baadnewsburr
you may want to pas onto him the template for the dimensions for cutting the pieces in the DIY on here, that should alleviate concerns about the s shape..its really not bad as far as curves in the flat plane go (which is a legitimate concern in wrapping), its more of an issue of odd dimensions that have to be cut out of the material
Old Feb 2, 2019 | 11:12 PM
rotarymike's Avatar
rotarymike
Thanks, I can do that.
jk315
Aug 15, 2016 11:50 PM
FlawlessZ
Southern California
Jul 30, 2012 03:03 PM
XxRoyerxX
VPP Purchasing
18
Sep 21, 2011 03:52 AM
