Brake/Tail LED burnt out
Old Nov 21, 2018 | 11:16 AM
presidentsdad's Avatar
presidentsdad
Hey all,
Do you know if its possible to fix an LED that is not working? I have one LED on my right hand brake/tail light that is out.
Old Nov 21, 2018 | 11:36 AM
zer099's Avatar
zer099
To my knowledge you will need to replace the entire tail light or cut open your tail, replace the LED by cutting it out and re-soldering in a new one, then plastic weld the unit back together. Sedan, correct? Which side?
Old Nov 21, 2018 | 12:42 PM
presidentsdad
Sedan=yes; right hand side.
Old Nov 21, 2018 | 02:41 PM
qmantran's Avatar
qmantran
Replacement used tail lights can be bought on ebay for $50
Old Nov 21, 2018 | 06:02 PM
iCrap's Avatar
iCrap
Yeah it's a sealed unit. I have a spare rear light if you are interested - although I have to check if it's a right side light.
Old Nov 29, 2018 | 10:38 AM
presidentsdad
Are all 2nd gen tail lights the same? Mine is a 2011, most of the lights seem to be from 2008 and 2009 G37's. Will those fit/look right?
Old Nov 29, 2018 | 10:56 AM
zer099's Avatar
zer099
There the same; what matters is sedan or coupe and USDM or JDM. I have a spare passenger side if that's the side you need. Would happily swap for yours. I have a back burnered project for them that doesn't require the LEDs, as long as the housing is fine and the lens is cosmetically okay. I work in Roswell. Let me know.
Old Dec 3, 2018 | 09:41 AM
presidentsdad
Mine is the passenger side, so I don't think that'll work. But...thanks for the offer.
McStealth
Oct 19, 2018 09:33 PM
pcwd
Aug 12, 2015 06:54 PM
Thirty_Seven
Aug 29, 2014 02:01 PM
blackg37coupezz
Mar 10, 2014 10:06 PM
Devildog37
Mar 2, 2010 06:34 PM
