'08 G37S Hi/Lo Beam Drivers Side
All,
I have NO Hi or Lo beams on the drivers side only, is this typically a bulb replacement or something more involved. New to new fangled lighting systems.
Thanks
Thanks
Search the forums.
It's a single bulb for both high and low. Take the bulb out of the driver's side. Assuming your passenger side works, remove that bulb and install the driver side bulb. If it turns on then it's the ballast. If it doesn't turn on then it's the bulb. Whatever you do DO NOT touch the glass on the bulb.
Check this link, your headlight low beam and high bean is the same bulb, you only need one bulb.
https://www.automotivebulbfinder.com/philips/
Another point, if one bulb doesn't work, you can change the bulb to anther side, if the bulb can work, you need a new ballast, if the bulbs can't work, you need a new bulb. If you are sure both of the bulb and ballast can't work, you may need to order a whole set, but most of the aftermarket HID bulb and ballasts are not very good.
Hope this can help you.
AzNBoY92
May 9, 2014 11:06 PM
ncitrdude
Aug 28, 2013 11:44 PM
