Bulb suggestions
Old Oct 3, 2018 | 06:07 PM
lektrix's Avatar
lektrix
Bulb suggestions
Looking for some bulb recommendations from RockAuto....... what do you guys think?
Wagner vs. Philips vs. HELLA brand. For some reason Philips is 2.5X the cost - is it worth it???
https://www.rockauto.com/en/catalog/...amp+bulb,11701
Old Oct 4, 2018 | 09:38 AM
takemorepills's Avatar
takemorepills
Lots of different kinds of bulbs on your car. Vanity, license plate, fog, doors, glove box, headlights, running lights..................
Old Oct 4, 2018 | 10:40 AM
lektrix's Avatar
lektrix
Sorry, thought I specified. Im wondering about the high/low beams on https://www.rockauto.com/en/catalog/...amp+bulb,11701..... according to RockAuto they're the same bulbs right???
Old Oct 4, 2018 | 01:40 PM
ILM-NC G37S's Avatar
ILM-NC G37S
When it comes to HID bulbs there are tons of opinions on which specific bulb is better/worse and why/why not, etc. The biggest specification between HID bulbs is the temperature (laymens terms: color) measured in Kelvin.
It is just a matter of researching and deciding which spec suits your taste and needs. I switched to Philips Ultinon 6000K in my G about 4 years ago and have not had one issue. For certain things I prefer name/quality branding but in the end it is up to your preference.
And, yes, there is only one (1) bulb needed for each side.
Old Oct 4, 2018 | 03:03 PM
lektrix's Avatar
lektrix
Does anyone know what the stock headlight bulbs are?
Old Oct 4, 2018 | 03:30 PM
ILM-NC G37S
The OEM bulbs are:
Type: D2S, 12Volt-35Watt
Temperature: 4300K
P/N: 26297-89900
Cost: $150/ea. from dealer.
Referencing the rockauto link, the Philips D2S or D2SC1 should do you well. I would recommend replacing both sides at the same time.
If you wanted a whiter light you could go up to 5500-6000K (anything higher and you get more blue/purple tinting to the light output).
Old Oct 4, 2018 | 03:35 PM
lektrix's Avatar
lektrix
The OEM bulbs are:
Temperature: 4300K
P/N: 26297-89900
Thanks. I know i can trust Philips. But I'm trying to avoid paying $50 each if the other brands are just as good. From what i read Wagner and Hella are also companies under Philips and all three are made in Germany??? If true all should be high quality yeah???
Old Oct 4, 2018 | 03:52 PM
ILM-NC G37S
I do not know who manufactures the bulbs for each brand. Could be the same but I just do not know.
In the end it is all up to individual preferences and budgets. Just follow your instincts.
Diode Dynamics
Lighting/Cleaning Products
188
Nov 30, 2021 02:36 PM
Diode Dynamics
127
Nov 30, 2021 02:20 PM
g35g37fan
Apr 27, 2021 10:47 AM
Diode Dynamics
258
Mar 19, 2021 04:14 PM
