Pulling apart tail lights
Old Jun 30, 2018 | 09:41 PM
rausch771's Avatar
rausch771
Hello all,
I apologize if this has been touched on in another thread, I did some extensive searching and couldn't find anything on it. I'm attempting to install the Ghozt sequencers on my tail lights, but can't seem to get the tail lights apart. I started with the driver's side (probably a bad choice). I've cut the entire tail light just behind the lens but something is still attached to the lens and I can't tell what it is. I think it might be a seal or something by the trunk button? That is the general area where it is still stuck and when I tried to pry a little bit, the lens cracked a bit by the hole for the trunk button. Does anyone have any experience in doing this? Any help/advice is greatly appreciated. And if you have any tips for installing the Ghozt sequencers on the electronic side, I would greatly welcome that help too! Thanks all!
Old Jun 30, 2018 | 10:23 PM
rausch771's Avatar
rausch771
Apparently my search wasn't good enough! Finally found a DIY someone did for painting the tail lights that touched on how to cut around the trunk button cut out to remove the back.
Old Jul 3, 2018 | 06:14 AM
Surfnazi's Avatar
Surfnazi
Thought you had to heat the light up either with an oven or heat gun to take the cover off
dholmblad
May 10, 2013 10:34 PM
romansiny
Jul 7, 2010 12:55 PM
dzine07
Dec 7, 2007 08:36 PM
