Notices
Skyline V36 370GT Type SP speedometer swap
Old 03-13-2018, 11:22 AM
Mcstikman
Mcstikman's Avatar
I have a 2007 Skyline V36 370GT Type SP ( Basically a G37s with 5 speed auto) and I'm looking to have the speedometer cluster swapped to the newer version found on 2010 Infiniti G37 and up as I hate the orange LCD and would like the white variant. Meter swaps in my country/ mileage is very lax so I don't even really care about mileage differences. What I would like to know is if an Infiniti speedo will be plug and play with the the difference being just the unit calculation (mph vs kmh) but basically function the same with no issues?
Old 03-13-2018, 11:36 AM
zer099
zer099's Avatar
You can just swap over the display, that's what I did. Plug and play. Keep everything else the same. You can swap over the gauge covers if you like the MPH better and mix and match needles as well, all while keeping the base cluster so it still outputs in KMP and has your odometer reading.
Bommerang (03-13-2018)
Old 03-13-2018, 11:55 AM
Mcstikman
Mcstikman's Avatar
That is basically what i would like to do but I'm not too savvy, do you know if I just connect the Infinti cluster will everything just function as it should? I'm thinking that would be the easier option. I'm guessing if that doesn't work out; do you have a DIY guide for your method.
Old 03-13-2018, 01:32 PM
zer099
zer099's Avatar
If I recall the wiring was the same, but I should not be quoted on that. I was going to go look up the FSMs for you to compare diagrams but apparently the manuals are offline right now. If all else fails I guess I can do a DIY for the display swap. I still have the old cluster in storage so I can take pictures; I just suck at follow through on those types of things.
Old 03-13-2018, 09:48 PM
Mcstikman
Mcstikman's Avatar
Ok, if you do make a DIY that would be appreciated
Old 03-14-2018, 11:53 AM
Whitevanman
Whitevanman's Avatar
what country you from then?
I nearly bought a type sp before settling for my type s.....
Old 03-14-2018, 12:18 PM
Mcstikman
Mcstikman's Avatar
I'm from St. Lucia in the Caribbean. I have the only Skyline coupe here, we did have a Canadian spec g37 but that got totaled last year.
Old 03-14-2018, 02:15 PM
Whitevanman
that's pretty cool that your the one and only on st lucia, there a rare car here in the uk as well.... that's why I imported one....
Old 03-22-2018, 03:36 PM
Mcstikman
Mcstikman's Avatar
Can anyone from AUS or UK confirm USDM cluster swap?
Old 12-15-2019, 11:46 PM
Mantix
Mantix's Avatar
Hi all ,
  1. Yes, you can swap instrumental clusters out with others of different colour etc. They are all pretty much interchangeable.
  2. However, the mileage will stay as what it was from what vehicle it was taken from.
I am working on being able to change the mileage on these units (in spear time) may be a while.
I'm trying to design it so I don't have to split dashes anymore.
FYI the US clusters will work in Japanese vehicles too, Same unit different language programmed on the LCD EEROM.
any more questions please email me with the heading "Nissan V37 help".
Mcstikman (12-25-2019)
04-20-2024 06:04 PM
Purist
03-21-2024 06:29 PM
slartibartfast
06-25-2020 01:57 PM
RAVSPEC
Brakes/Suspension
06-21-2018 01:10 PM
Superman_G37S
01-05-2017 06:53 PM
Quick Reply: Skyline V36 370GT Type SP speedometer swap
