Sensitive power windows adjustable?
Hey all,
Been a proud owner of a 2010 G37X for almost a year now and only issue besides damn Bluetooth that I found a crappy workaround for is that the power windows are WAY too sensitive. The switches that is. They work fine just too touchy!
What I mean is it takes the lightest touch to move them up or down just a bit and not have them go full throttle up or down.
Ive researched best I could on Net and owners manual/encyclopedia
and found no answer.
Is there a workaround for this to adjust it?
Thanks to any and all responses!
and found no answer.Is there a workaround for this to adjust it?
maybe the previous owner pressed it too hard or too often and the button wore making it soft to press. it shouldnt be soft. probably try buying a used console and replace it if it bothers u that much
Absolutely agree with you. I have on many occasion activated auto when only wanting to roll down a little. though I don' really think there is any option on this matter besides a complte custom mod. if you do find one tho defiantly share.
(this thread could go way off track..... must resist....
What I've noticed is a Quick Flick of the switch activates the Full Auto. Try holding the switch just a little longer before you release it.
)What I've noticed is a Quick Flick of the switch activates the Full Auto. Try holding the switch just a little longer before you release it.
GTLAW
Jan 31, 2013 02:04 PM
